Indoor TV for Outdoor use (under $500)
  • macallan
    • 5
    We are currently adding a covered deck to our house and would like to add a TV (ceiling mounted) that will sit in the upper corner of our covered deck. I have heard that buying a moderately price (less than $500) display is a good option vs. a true outdoor TV. This will be used almost exclusively for sports and I plan to use YouTube TV as the source so it needs to be a smart TV. I have found a Samsung 50" AU8000 for $450 that looks like a good option but wanted to know if anyone had any insight if other brands would hold up better for outdoor use? The TV will be under a roof and not directly exposed to the elements and I plan to purchase a protective cover for it when not in use. Any input would be helpful. I like Samsung but LG, Hisense, TCL, Sony, Vizio would all be potential options as well.
    • 1578
    I can't imagine any of them would necessarily be better in an outdoor environment than any other. I've had good luck with TCL so far in my 'budget' applications - though my first one did arrive with a broken screen. You can't really argue the price. I'd have to check if they have VESA mounts but I assume they do.
      Master of None
      • Jan 2014
      • 1665
      I tend to always go to Costco for a new screen and wait till I see a good deal there. All my TV's are LG, mainly because I like the menu system better. If you have a Costco, Sams, or BJ membership check there for any deals too.
      Painter in training
      • Vincehoffman
        1st Post: Looking for advice on DIY Outdoor Sub.
        by Vincehoffman
        Hi All,
        I'm a long time lurker, very much into quality music reproduction and HT, and was once a DIY speaker builder (in high school!). My reason for this post is the tremendous knowledge base (or is that bass ) found here and that no commercially available product appears to fit the...
        29 August 2007, 19:57 Wednesday
      • engr_dave
        Outdoor application - high-power sat-sub system
        by engr_dave
        Hi forum... 'beena while since I posted. Currently working on backyard with pool renovation, multi-level deck (about 1500 sqft concrete and 500 sqft ipe hardwood) incl. outdoor kitchen, fire pit, water feature, etc. Interested in building a pair of speakers under a covered patio to "rock the...
        04 May 2021, 09:40 Tuesday
      • chuck21401
        Integra DTR 40.1 - Zone 2
        by chuck21401
        I recently purchased an Integra DTR 40.1 receiver to replace my older Onkyo receiver. Before the Integra I had a TX-DS 939 and before that a TX-DS 747. The Integra is a great leap forward and sounds great.
        I am using the Integra in a home theater set up and have two outdoor speakers...
        05 January 2010, 12:51 Tuesday
      • ChiefKeefe
        Need some advice for HT...must add/upgrade
        by ChiefKeefe
        I'm looking for advice on what piece to add to the puzzle or upgrade to next make in my HT system:
        Sony SXRD 60" TV
        Sony STR DA3-ES Receiver (5.1 in HT and drives 2 outdoor speakers on the deck)
        Denon 1920 DVD
        DirecTV HD receiver w/ TiVo
        Klipsch center...
        07 June 2006, 10:15 Wednesday
      • june
        indoor antennas?
        by june
        Hello All,
        I need your recomendations for a indoor antenna for our RT-02 tuner. The antenna that comes with the tuner works good. But we are looking for a great antenna. Have anyone heard of Godar's indoor antennas?
        02 May 2005, 10:38 Monday
