QUESTION??--What brand of VCR has the best all alround tuner in it?? THANX HOWARD
Help
BAM! you can use the tuner in a VCR as a channel-controller for TVs that don't have them - or as a second tuner for picture-in-picture capable TVs that only have one tuner..
I don't think it really makes much difference from one to the other. The biggest difference in VCR's is regular VHS and S-VHS. Other than that buying a model from a well known company will likely get you higher quality components overall but VCR's are pretty much at the end of their lives, in fact why are you even buying one?
JasonJason- Bottom
Originally posted by aud19I don't think it really makes much difference from one to the other. The biggest difference in VCR's is regular VHS and S-VHS. Other than that buying a model from a well known company will likely get you higher quality components overall but VCR's are pretty much at the end of their lives, in fact why are you even buying one?
:rofl:
well I wan`t thinking of a TV tuner
ops: my super bad!
ops: I was thinking radio! :lol:
Wow this goes under :loser:Got a nice rack to show me ?- Bottom
Howard
Some years ago Panasonic made VCR's that where known for high quality tuners. They did infact made "world wide" models where the tuner could be used in all parts of the world. Not to be mistaken by the ability to play all kinds of tapes (NTSC, PAL, SECAM, MESECAM, etc)
Dont know if they still do..- Bottom
by Bing FungAnyone have thoughts on This TV tuner Card from Asus?
It uses Conextent's newest CX23880 Decoder with 10bit Video ADC's which are said to capture near DVD video quality with a good Satellite or cable feed. It's max capture resolution is 720x480, so that should... -
by Dean McManis"Digital" is a buzzword today, and it is regularly abused. Most "digital" cable is NOT transferring high definition digital signals, but they are transferring the 480i NTSC analog signals into digital format, so that they can compress them, to get more channels across the line. So... -
by Matt Broeskahey everyone. just this past weekend my vcr died. no! no need for tears or condolences... i'll be okay. afterall, it's just a vcr. one of those $150 (cdn) things that only lasted 3 years.
so now i wanna replace it and i'm wondering whether i should go with an s-vcr or not. it's YOUR job... -
by toychrisI was wondering if any of you could give me a good reccomendation on a VCR. Is there any VCR's with component outputs that are reasonably priced? I am guessing that VCR's Video output is relatively low anyway, so s-video outputs would give about the highest quality of picture, right? I know that JVC... -
by MaulerHi. I have a Panasonic SC-HT800V DVD Home Theatre Sound System. This is similar also to their SC-HT700, SC-HT790V, SC-HT810V, and SC-MT1 systems.
Channel: Audio Hideout
- Loading...
- No more items.
