Z2 Sanyo noise
  • cadman
    • Sep 2003
    • 73
    Z2 Sanyo noise
    OK this is for people that can take a chance on there Z2 sanyo
    I hate that noise when its put to the max light output
    I opened mine to investigate and there are 2 fans for the outlet
    fan model 2810kl-04w-b39
    12V=DC 0.19A
    DC BRUSHLESS +RED -BLACK
    MINEBEA CO., LTD 7
    MADE IN CHINA
    BRUSHELESS
    DC pICO aCE 25
    MODEL 9RH0612S4D03
    DC 12V 0.14A
    SANYO DENKI
    MADE IN PHILIPPINES
    and this is what it sayes on them
    so I am looking for less desibells (I hate noise)
    can anybody help
    thanks :roll:
  • Legairre
    • Jan 2002
    • 231
    I'm surprised you use max lamp mode. My Z2 is running on low lamp mode with the iris fully opened and it's more than bright enough. Also max mode will shorten your lamp life. What's the gain of your screen, do you have control of the rooms lighting? Last but not least has your Z2 been calibrated with AVIA or DVE?
    I really wouldn't mess with the fans in the Z2. Swapping them out with other fans could result in less air flow and cause redused lamp life or overheating. Your best bet is to use low lamp mode. High lamp mode is too loud for most people and I agree very distracting.
    "What do you mean it's too loud? My ears aren't even bleeding yet!"
    Radden Home Theater
    • Bam!
      • Jan 2004
      • 2458
      AND or build a hush box.....
      Got a nice rack to show me ?
      • cadman
        • Sep 2003
        • 73
        Z2 Sanyo noise
        My gain on the Luma from Drapper probably has .09 gain (not sure).
        I like a bright picture - I do not mind that it shortens the lamp life. I have control over the lighting for I watch mostly at night. I did calibrate but still too dark
        I find that it does not have that punch of colours when it's full blast.
        Thanks for the advice about swapping fans (but I am no fool )
        I am looking for less db and the same flow of air or better for I do it on my PC
        (overclock) and I keep it very cool -- the secret is better fans
        thanks for the advice (Bam)
        AND or build a hush box..... I find it's not too good for heat despertion
        • Legairre
          • Jan 2002
          • 231
          Cadman,
          I never implied that you were a fool.
          Based on your comments even on full blast (I assume you mean high lamp mode) the colors lack punch. If that's the case then even with quieter fans you'll still have a picture that does not have the punch or brightness you want, but will be quieter. Maybe another member can offer help with the fan replacement, but based on your punch/full balst comment it sounds like you have a screen problem.
          If I'm not mistaken the luma screens come in matte white and grey and range from .08 for a HC grey and 1.0 for a matte white. If your screen is grey and .08 gain then you have a very dark negative gain screen. This kind of screen will lack punch, reduce brightness, and make sunny days seem a bit overcast compared to positive gain screen, but give REALLY good blacks . If this is the type of screen you have then a positive gain screen like a Dalite HCCV or HCMW which are light grey screens with a 1.1 gain would give you the punch and increase the brightness.
          Radden Home Theater
          • cadman
            • Sep 2003
            • 73
            Z2 Sanyo noise
            Well thanks Legairre for the reply
            the screen is grey (and I have no problem with the fool stuff heheheh)
            and when I put the Z2 full blast its ok but could be better .
