PANASONIC PT-AE 200 Need help fast!!!
  • Bam!
    • Jan 2004
    • 2458
    Hey guys!
    What do you think of this piece for 1800.00$ Canadian + taxes
    Is there better for the money...how good is it ?
    Thanks!
    Bam!
    Got a nice rack to show me ?
    • 27460
    What are the specs on it? 800 X 600? LCD?
    Lex
    • Paul H
      • 904
      That seems like a reasonable deal, but no 'race out and get it right now price'.
      To assist others who wish to comment, specs are as follows:
      PT-L200U
      700 ANSI Lumens 16:9 Native Micro-Cinema Projector
      U.S. List Price: $1,999.00
      PT-L200U
      Features
      700 ANSI lumens brightness
      Digital keystone correction
      700:1 Contrast Ratio
      16:9 wide screen LCD panels - 4:3 compatible
      858 x 484 resolution
      Whisper-quiet 28dB
      6.4 lbs
      SD memory card slot
      6 picture modes
      Up to 5000-hour lamp life
      Color temperature adjustable
      Optional ceiling mount
      Multi-function wireless remote
      2-watt speaker
      Enhanced noise reduction technology
      One-year limited warranty
      Bam, check out the Sanyo Z1 at Quebecacoustic.com. It looks comparable in features for just under $1700.
      Paul
      • Bam!
        • Jan 2004
        • 2458
        Thanks Paul...
        I was just about to post those specs for Doug`s question....
        Thanks for the comments and reply I appreciate it bud
        If you guys have any other sugg in the 2000.00$ or less range than don`t be shy.... this is for my buddy and he wants to buy it within the next couple of weeks...
        Take care and thanks again!
        Bam!
          • 27460
          I think if I was gonna go a Sanyo, I'd tell him to scrape together another 800ish and get a Z2. That's a real crowd pleaser.
          I think the Panny will be a pretty nice projector. If he needs to run it in daylight though, he may need to look for a bit more lumens. However, the Lumens is not always a true indicator of brightness anyway. Read a review or two, that's a good place to start.
          lex
          • Dean McManis
            • May 2003
            • 762
            Unless you had a problem with DLP projectors, I'd choose the InFocus X1 instead. It costs a couple hundred (Canadian) more, but you get better light output, much better contrast, better blacks, and comparable resolution.
            -Dean.
            • Bent
              • Sep 2003
              • 1573
              I don't want to get into trouble posting dealer links, but the X1 can be found in Canada for less than 1400 bucks...
              I'd do some searching if I were you...
              • Bam!
                • Jan 2004
                • 2458
                Bent!
                That's right 8O !!!!Wowowowowowowowowowowowo!
                I called and the guy told me they have an Infocus model #???? that is like the X1 but is made for Home Theater and it sells for a couple hundred more!
                anyone know about that response 8O !
                Thanks man you guys ROCK! :-y
                Bam!
                  • 16478
                  Bam I sent you an email to some vendors that might be of interest.
                  check out the Studio Experience 1HD as well before buying anything else.
