Sound Transparent Screens?
  • maseline_98
    • 317
    I will be moving into a bigger home and will be getting a projector/screen combo. I would like to put my front channels speakers behind the screen. Is there a screen available that will not dissipate the sound? I was looking at the black diamond zero edge screens, but I didn't see any mention of that on the website.
    Sony kds-60a2000\Panasonic BD-55k\XBOX 360 Premium(20gig)Slingbox\Xbox(flashed) running XBMC
    Emotiva UMC-1\Emotiva XPA-5\Klipsch (2)RF-7s with DeanG xover upgrade, RC-7 with DeanG xover upgrade, (2)RS-7s\SVS 20-39PC+
    _____________________________
    “Insanity: doing the same thing over and over again and expecting different results.” - Einstein
  • Kevin P
    • 10808
    You'll need a perforated screen (has lots of tiny holes in it) to let the sound through.
    • Kevin D
      • 4601
      We've actually switched to woven screens for acoustic transparent. With DLP/LCD/LcOS projectors a perforated screen can cause a moire effect without correct placement of the projector.
      You'll get the moire when the pixels line up with the holes in the screen. Do a search to see what it could look like.
      Kevin D.
      • madmac
        • Aug 2010
        • 3122
        Remember one thing, sonically there is a compromise there and as mentioned above, probably a video compromise as well. If you do go for it, remove the grills on the speakers behind the screen so at least the sound doesn't have to travel through 2 barriers!!.
        Dan Madden :T
          • 16877
          Yes, I used an acoustically transparent screen in my previous theater, and it was AWSOME!!! I still believe that you have to have one for the ultimate setup, with perfect sound imaging directly in the middle of the screen.
          • maseline_98
            • 317
            I was thinking the same about imaging, but if you lose PQ, is it really worth it?
              • 16073
              Well you don't really lose quality, you lose brightness. Generally most projectors these days are way to bright for a light controlled theater anyways.
                • 16877
                Dougie's right. My theater worked fine, with a 119" screen, and a Panny PT-AE700 projector that's several years back for model offerings, so it wasn't as bright. Theater was light controlled. There was zero loss of actual picture quality.
                • maseline_98
                  • 317
                  Well...the question is, is it worth it to go with an acoustic transparent screen then?
                    • 16073
                    If it's a light controlled room you'd likely see an improvement because generally you have to turn the brightness way down anyways because of how bright current projectors are. So yes I think there is a great benefit and well worth it.
                      • 16877
                      maseline, for me, it is.
