Small Bedroom TV
  • htsteve
    • 1216
    Small Bedroom TV
    Knowledgable ones,
    We have a small bedroom and would like to put a small TV in it. The following characteristics are what we are looking for. Price is a consideration, but not the primary one, that's why I didn't list it.
    20" or so
    HDTV
    Wall mountable
    Widescreen
    I'm looking for recommendations and/or viewing experience.
    Thanks for any help you can provide.
  • Snap
    • 1295
    I personally like the Toshiba for bedrooms. I had a 27 inch LCD with built in DVD player. I have not used something smaller in the bedroom. I do have a 20 inch LCD in the master bath. The 20 inch in the master bath is a Westinghouse. But I really like the Toshiba with built in DVD player.
    I would go with Toshiba and the DVD player for cost, and quaility.
    I do not have the 27 inch in my new house cause I upgraded to a 42 inch plasma and a complete surround sound. But the 27 inch LCD/DVD combo worked great.
    Good Luck.
    • peterS
      • 1038
      satelite, cable or antena?
      • dyazdani
        • 7032
        My parents have a 26" Toshiba LCD in their house, it is quite nice. It was a bit spendy at the time, but the prices have come down nicely since then.
        Danish
        • htsteve
          • 1216
          Satellite. I already have the directv HD package in the main setup. We would simply get a new HD receiver for the bedroom.
          dyazdani,
          I've beginning to look at the Toshiba's.
          • peterS
            • 1038
            the toshibas darks can look purple of axis
            • peterS
              • 1038
              id give this one a look if you watch mostly tv http://www.sonystyle.com/is-bin/INTE...atpanel_15to23
              this one if more movies http://www.sonystyle.com/is-bin/INTE...atpanel_15to23
                Twin Moderator Emeritus
                • 16706
                LCD is pretty much your only choice currently given your criteria. I'd recommend a Sony or Sharp model.
