im looking for a good projector for my living room.im looking to spend up to $3000 on just the projector alone.i heard DLP was better picture quality but i dont mind lcd if dlp is not in the price range. thanks
Need help choosing a projector for living room
Hi, Delon. You probably haven't gotten a response because there are many variables you have to consider before buying a PJ and you didn't give much information. For example, you need to know room length and where you plan to place the projector in the room, and the size screen you hope to use, because these things will determine throw distance and projectors have different throws. Why not go to the Projector Central website. They show just about every PJ in that $3K range in both lcd and dlp. And each has a throw calculator in the specifications.
Hope this helps.- Bottom
by Brandon BGot a chance to check out this unit:
http://www.christiedigital.com/Products/products.asp?Port=2&ProdPartNo=38-VIV501-01
My impressions to follow. Some notes though. This was a short test just to check out the suitability of this unit as an HT projector. My standard... -
by Shane MartinBenq has one out now.. Seems rather amazing..
BenQ Expands Line of Award-Winning Home Theater Digital Projectors
PE7700 Features Latest HD2+ DMD Chipset from Texas Instruments, 1000 Lumens,
a 2500:1 Contrast Ratio and 6-Segment Color Wheel for High Performance ... -
by BentGreetings,
Although I currently have a Widescreen RPTV, I am trying to keep up with the fast-paced-ever-changing world of LCD and DLP projectors, one of the hang-ups I have with them is you can get a short throw pj (Panasonic AE series), or a long throw (Sony VPL-400Q, I know it's long in the... -
by SZ99I need to project an image that is about 3 inches wide (diag). Therefore, I need a projector that has a very short throw distance and that makes very small images (obviously I am not planning to use it as a regular projector). Also, the technology must be DLP. Does such a product exist or what is... -
by sokobanHey, if anyone is interested, Woot.com has a 480p projector today for $650 with a 76 inch screen. here is the info on the projector and screen
Features:
* Native Aspect Ratio: 16×9
* Supported Aspect Ratio: 4:3, 16:9
* Brightness: High Bright:...30 October 2006, 19:49 Monday - Loading...
- No more items.
