I have a SP7205 that is quite loud. Are there any guides to making a Hush Box? Thanks.
Help on Making a Hush Box
by cjdFinally got my workshop into working order, and barely in time for a little gift-making. Not done unpacking, but through just about everything we can do without said workshop to build things like bookshelves...
Anyway, a little box-making practice, as it were.
Figured purple-heart...-
Channel: Mission Possible DIY
by KennyGWell the Projector looks pretty good, and I've promised myself to stop adjusting it for while, I can only work on my Hush box during the day/ waking hours, so I need a silent, later night project...you say, Kenny, what could you do late at night that won't wake the family???
HTPC mods!!!... -
by ti33erWell well well, the UK has finally graced us Brits with the much talked about Infocus 4805!
I had a demo yesterday afternoon, and without a shadow of a doubt, handed over my plastic wallet within 30 minutes – we did a side-by-side comparison with the Infocus 5700, and I tell you what,... -
by BlazeMasterI'm trying to build a hush box for my projector. Found 2 120mm fans and a power supply. I plugged the power supply into the wall and plugged in the fans, but there seems to be no power coming from the power supply. Do I need another separate switch, even though the back of the power supply has a... -
by Greybeard191I'm playing around with a Tumult 15D2 in Unibox and I've run into what seems to be a conflict.
If you build a 2 cu ft box and set input power to 1000 watts, Unibox says on the sealed box that that excursion of 33mm is exceeded at about 30 hz or slightly under (on one of the graphs). Yet...-
- Loading...
- No more items.
