I have Comcast cable and a Motorola HD box hooked up to an Infocus 7205 projector. The projection has a native resolution of 720p. The cable box has several HDTV display output options, including 720p and 1080i. Should I set the box to 720p and the projector's aspect to native, or should I set the box to 1080i and the projector aspect to 16:9? Also, does the picture look better through DVI of component connectors? Any help will be appreciated.
Display setting for Motorola HD Box
It depends on what has better scaling, your display or the Motorola box. If you're display has better scaling, hopefully the HD box has a "passthrough" or similar setting to send through whatever signal the broadcaster sent it in (480i/p 720p or 1080i) untouched and allow the set to scale it. If the HD box has better scaling, set it to output your sets 720p resolution and you're good
Jason- Bottom
The box doesn't have a native setting last I looked. My STB DCT 6412 has a setting for Aspect Ratio and what resolution you want and also what resolution you want for SD stuff.
What you should do is set your box to output to 720P and connect to it via DVI(better PQ and all digital).
Then for 4x3 stuff decide whether you want the box to stretch or not.- Bottom
by kiwi2000The 1069 has the video bypass installed yet continues to cause problems when the Motorola HD DVR is routed through it.
The problem I have is with the 4:3 override setting on the PVR.
When the box is powered up or the display turned on or the 1069 turned on or any of these...-
Channel: Club Rotel
by LexWell, I quitely added this TV to supplement my front projection since I saw real quickly that I was going to crank a lot of hours on my PJ in a hurry. It's an HDTV monitor, the following applies: (Extracted from Plasma Depot since it was actually better than Sony's writeup.) I won't address each feature... -
by LexI went out to Now Audio Video one evening to look at progressive scan DVD players, thinking maybe I'd find something I liked. So, I rolled in the store right at 8:00 PM, thinking I had 1 hour to look. I didn't know 9 months ago they changed their store hours to close at 8! GRRR. They did unlock the... -
by vasiaI am trying to hook up Motorola digital cable box DCT2500 to my Marantz SR8300 receiver. I connected digital out of the DCT2500 (did not have optical out) to the digital in of the Marantz and it plays fine. THe only problem is that even when the program is listed on the TV as Dolby Digital, the receiver...-
by comeupWhats up fella's,
I just bought a Pioneer pro940hd for the bedroom what a picture and (who needs 1080P)I got it for a steal. Guys I probably should know this, but what setting should I have my hd set-top box set to. My choices are 480i,480P,720P and 1080i its a Dish Network system. I... - Loading...
- No more items.
