Exploring Common DIY Terminology - Sd
  • Exploring Common DIY Terminology - Sd
    Sd (Thiele/Small Parameter)
    Sd, also known as the effective piston area, plays a crucial role in loudspeaker design. It represents the effective surface area of a driver's diaphragm or cone that interacts with the air to generate sound waves. The importance of Sd in loudspeaker design can be understood in several ways:
    • Efficiency and sensitivity: The diaphragm area, as represented by Sd, directly affects the loudspeaker's efficiency and sensitivity. A larger diaphragm area can move more air with each excursion, resulting in higher sound pressure levels (SPL) for a given input power. Therefore, a driver with a larger Sd tends to be more efficient and sensitive, requiring less power to produce a desired volume level.
    • Low-frequency response: Sd also influences the loudspeaker's ability to reproduce low-frequency sounds. The diaphragm's surface area determines the driver's ability to displace air, which is crucial for generating low-frequency output. A larger Sd allows for better low-frequency response and improved bass reproduction, as it can move more air with each excursion.
    • Box volume calculation: Sd is also used in loudspeaker enclosure design to determine the required box volume for a given woofer or subwoofer. The diaphragm area influences the air compliance and velocity within the enclosure, affecting the loudspeaker's low-frequency response and overall system performance. Properly matching the box volume to the driver's Sd helps optimize the system's bass extension and efficiency.
    Accurate measurement and specification of Sd are crucial for loudspeaker design. It allows designers to select and combine drivers with appropriate diaphragm areas for a specific application, considering factors such as efficiency, sensitivity, and low-frequency response. Additionally, Sd facilitates accurate modeling and simulation of loudspeaker behavior, aiding in the optimization of system performance and enclosure design.
    Main Page
      Posting comments is disabled.
    Latest Articles
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
    • Exploring Common DIY Terminology - SINAD
      by technodanvan
      SINAD (Signal to Noise and Distortion ratio)
      While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...
      26 July 2023, 07:41 Wednesday
    • Exploring Common DIY Terminology - Signal-to-Noise Ratio (SNR)
      by technodanvan
      The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
      The formula to calculate SNR in decibels is:
      SNR (dB) = 10⋅log⁡10(PowerSignal/PowerNoise)
      25 July 2023, 15:20 Tuesday
