Exploring Common DIY Terminology - Xmech
  • Exploring Common DIY Terminology - Xmech
    Xmech (Thiele/Small Parameter)
    Xmech represents the maximum physical distance the diaphragm or cone can move before it encounters mechanical limitations. Exceeding the mechanical excursion limit can lead to high levels of distortion, increased nonlinearity, and potential physical damage to the driver. The mechanical excursion capability is a critical parameter for loudspeaker design as it directly affects the loudspeaker's ability to handle high power and reproduce low-frequency signals accurately. Xmech is typically measured in millimeters (mm) and is always a larger value than Xmax. The importance of Xmech lies in four aspects of loudspeaker design and usage:
    1. Power handling: The mechanical excursion limit determines the maximum power that a loudspeaker can handle without encountering mechanical failure. By ensuring that the diaphragm remains within its safe excursion range, designers can optimize the loudspeaker's power handling capabilities and ensure its long-term reliability.
    2. Low-frequency performance: Xmech influences the loudspeaker's ability to reproduce low-frequency sounds with accuracy and sufficient volume. It defines the maximum displacement of the diaphragm, allowing it to move air effectively and generate low-frequency output without damage.
    3. Enclosure design: The mechanical excursion limit is a crucial consideration in loudspeaker enclosure design. Proper enclosure design helps optimize the loudspeaker's low-frequency response and prevent detrimental effects caused by excessive excursion.
    4. Protection mechanisms: Xmech is also relevant in the implementation of protective mechanisms in loudspeaker systems. Various techniques, such as limiters or high-pass filters, can be employed to ensure that the loudspeaker operates within its safe mechanical excursion range, preventing damage due to excessive excursion.
    Accurate knowledge of Xmech allows loudspeaker designers to select appropriate diaphragm materials, suspension systems, and motor structures that can handle the required mechanical excursions while maintaining optimal performance. Testing and characterization techniques, such as Klippel testing, help determine the precise mechanical excursion limits of a loudspeaker.
    Main Page
      Posting comments is disabled.
    Latest Articles
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
    • Exploring Common DIY Terminology - SINAD
      by technodanvan
      SINAD (Signal to Noise and Distortion ratio)
      While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...
      26 July 2023, 07:41 Wednesday
    • Exploring Common DIY Terminology - Signal-to-Noise Ratio (SNR)
      by technodanvan
      The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
      The formula to calculate SNR in decibels is:
      SNR (dB) = 10⋅log⁡10(PowerSignal/PowerNoise)
      25 July 2023, 15:20 Tuesday
