Le refers to the voice coil inductance of a loudspeaker driver. It is an electrical property that plays a significant role in the driver's performance and behavior. The voice coil is a wire wound around a hollow cylinder called the former and is attached to the loudspeaker's diaphragm or cone. When an audio signal is passed through the voice coil, it interacts with the magnetic field generated by the permanent magnet or electromagnet surrounding the voice coil. This interaction produces the driving force that moves the diaphragm and produces sound. However, the voice coil itself has inductance, which is represented by the symbol Le. Inductance is a property of an electrical circuit that opposes changes in current. In the case of a loudspeaker driver, Le manifests as an impedance or resistance to changes in the audio signal passing through the voice coil. The presence of Le in the voice coil has several effects on loudspeaker performance:
- Impedance variation: The inductance of the voice coil causes the driver's impedance to vary with frequency. At higher frequencies, where the signal's rate of change is faster, the inductive reactance increases, leading to an increase in impedance. This variation can affect the driver's overall frequency response.
- Electrical time constant: Le, along with the driver's electrical resistance (Re) and any added electrical capacitance (Ce), forms an electrical time constant (Le/Re or Le/Ce). This time constant determines the driver's response to changes in the audio signal and can impact its transient response and ability to accurately reproduce fast transients.
- Distortion and nonlinearity: The varying inductance can introduce nonlinearities and distortion in the loudspeaker's output. These nonlinearities can affect the accuracy and fidelity of the reproduced sound.
Main Page
