Exploring Common DIY Terminology - Bandpass (Crossover Filter)
  • Exploring Common DIY Terminology - Bandpass (Crossover Filter)
    A bandpass filter refers to an electronic circuit or signal processing technique used to limit the frequency range of an audio signal that is sent to a specific driver or set of drivers within a loudspeaker system. It is employed to ensure that each driver operates within its intended frequency range and to achieve a desired frequency response for the overall system. For the DIYer, a bandpass crossover filter would typically be seen in a 3-way loudspeaker design on the midrange driver. While higher order systems such as 4- or 5-way loudspeakers would also employ bandpass filters, they are rarely seen in the DIY world. A bandpass filter consists of two main components:
    • Low-Pass Filter: This filter attenuates frequencies above a certain cutoff frequency, allowing only low-frequency signals to pass through. It is typically used to direct bass or low-frequency signals to a dedicated driver. For more information see Low-Pass Filter.
    • High-Pass Filter: This filter attenuates frequencies below a certain cutoff frequency, allowing only high-frequency signals to pass through. It is commonly used to direct mid-range and high-frequency signals to the appropriate drivers. For more information see High-Pass Filter.
    By combining both the low-pass and high-pass filters in the appropriate configuration, the bandpass filter ensures that the midrange driver used within the loudspeaker system receives the frequencies it is best suited to reproduce, while preventing it from handling frequencies outside its optimal range. This helps to optimize the performance, efficiency, and overall frequency response of the loudspeaker system.
    Main Page
      Posting comments is disabled.
    Latest Articles
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
    • Exploring Common DIY Terminology - SINAD
      by technodanvan
      SINAD (Signal to Noise and Distortion ratio)
      While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...
      26 July 2023, 07:41 Wednesday
    • Exploring Common DIY Terminology - Signal-to-Noise Ratio (SNR)
      by technodanvan
      The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
      The formula to calculate SNR in decibels is:
      SNR (dB) = 10⋅log⁡10(PowerSignal/PowerNoise)
      25 July 2023, 15:20 Tuesday
