Exploring Common DIY Terminology - Breakup Modes
  • Exploring Common DIY Terminology - Breakup Modes
    Breakup Modes
    Breakup modes refer to the resonant behavior or vibrations that occur when the diaphragm or cone of a loudspeaker driver starts to deform and produce undesirable sound artifacts at certain frequencies. Such resonances can be caused by various factors including the inherent stiffness and mass of the diaphragm, its shape, and the material(s) used. Breakup modes typically manifest as peaks and dips in the frequency response of the driver, indicating that certain frequencies are being emphasized or suppressed due to the resonance. These modes introduce unwanted coloration and distortion, affecting the accuracy and clarity of the reproduced sound. To mitigate breakup modes, loudspeaker designers employ several techniques, only some of which are available to the typical DIYer:
    • Cone/Diaphragm Design: The shape, composition, and construction of the diaphragm are carefully engineered to reduce resonances. This involves selecting appropriate materials, optimizing the cone profile, and adding structural reinforcements or damping treatments to minimize unwanted vibrations.
    • Spider and Surround Design: The spider (also known as the suspension) and the surround that connect the diaphragm to the speaker frame play a role in controlling breakup modes. These components are designed to provide proper compliance and damping to prevent resonances and maintain control over the diaphragm's motion.
    • Cabinet Design: The enclosure or cabinet that houses the loudspeaker driver can affect breakup modes. By employing adequate bracing, damping materials, and appropriate cabinet dimensions, resonances and vibrations can be minimized.
    • Crossover Design: The crossover network, which divides the audio signal into frequency bands for different drivers, can also be designed to address breakup modes. By properly selecting crossover points and slopes, designers can reduce the energy sent to frequencies that trigger resonances in the driver.
    Overall, controlling and minimizing breakup modes is crucial in loudspeaker design to ensure accurate and faithful reproduction of the audio signal without introducing unwanted artifacts or coloration.
    Main Page
      Posting comments is disabled.
    Latest Articles
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
    • Exploring Common DIY Terminology - SINAD
      by technodanvan
      SINAD (Signal to Noise and Distortion ratio)
      While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...
      26 July 2023, 07:41 Wednesday
    • Exploring Common DIY Terminology - Signal-to-Noise Ratio (SNR)
      by technodanvan
      The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
      The formula to calculate SNR in decibels is:
      SNR (dB) = 10⋅log⁡10(PowerSignal/PowerNoise)
      25 July 2023, 15:20 Tuesday
