Vas (Thiele/Small Parameter)
Vas stands for "equivalent compliance volume" or "effective volume of compliance". Vas represents the volume of air that has the same compliance (springiness) as a driver's suspension system. In other words, it measures the air volume that would produce the same acoustic compliance as the driver's mechanical suspension. Vas is typically expressed in liters (L) or cubic feet (ft³) and is an important parameter when designing loudspeaker enclosures.
The value of Vas is determined through testing and analysis of the driver's electro-mechanical parameters, such as the stiffness of the suspension and the effective radiating area of the cone, and refers to how easily it moves in response to changes in air pressure. A higher compliance means a larger Vas, indicating that the driver's suspension is more flexible.
Vas plays a significant role in determining the low-frequency response of a loudspeaker. It is used in conjunction with other Thiele/Small parameters, such as the driver's resonant frequency (Fs) and the total system Q (Qts), to calculate the optimal enclosure volume and tuning for the loudspeaker. The Vas value helps in designing enclosures that match the driver's characteristics and provide optimal low-frequency performance. In general, a larger Vas indicates that the driver is better suited for low-frequency reproduction and might require a larger enclosure. Conversely, a smaller Vas suggests that the driver is more suitable for compact enclosures and might excel in applications where size constraints are a concern.
Main Page
Main Page BB Node
Exploring Common DIY Terminology - Vas
Created by:
technodanvan
- Published: 31 July 2023, 15:00 Monday
- 77 views
- 0 comments
Categories
article_tags
- Audio Components (1)
- baffle step (1)
- blu-ray (1)
- build (1)
- community (1)
- crossover (2)
- dac (1)
- definitions (1)
- design (1)
- diy (9)
- diy forums (1)
- diy speaker (7)
- Floor standing Speakers (1)
- fs (1)
- glossary (1)
- Home Theater components (1)
- infinity baffle (1)
- measurements (5)
- rew (2)
- room eq (1)
- speaker (2)
- speaker diy (1)
- terminology (5)
- vas (1)
- vituixcad (8)
Latest Articles
by technodanvanSuspension
The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.- Spider: The spider, also known as the "speaker
Channel: Terminology
26 July 2023, 08:28 Wednesday -
by technodanvanSurround
In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...-
26 July 2023, 08:17 Wednesday -
by technodanvanSpider
In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...-
26 July 2023, 08:06 Wednesday -
by technodanvanSoundstage
Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...-
26 July 2023, 07:58 Wednesday -
by technodanvanSINAD (Signal to Noise and Distortion ratio)
While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...-
26 July 2023, 07:41 Wednesday -
by technodanvanSignal-to-Noise Ratio (SNR)
The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
The formula to calculate SNR in decibels is:...
SNR (dB) = 10⋅log10(PowerSignal/PowerNoise)-
25 July 2023, 15:20 Tuesday -
