Exploring Common DIY Terminology - Bl
  • Exploring Common DIY Terminology - Bl
    Bl (Thiele/Small Parameter)
    Refers to the Bl product, also known as the force factor or motor strength of a loudspeaker driver. It is a key parameter used to describe the performance characteristics of a driver’s motor assembly. Bl is a measurement of the interaction between the magnetic field generated by the driver's permanent magnet and the current flowing through its voice coil. It determines the ability of the driver to convert electrical power into mechanical motion and produce sound. The Bl product is typically given in units of Tesla-meters (T·m). It is calculated by multiplying two key parameters of a given driver:
    • The magnetic field strength in the voice coil gap, usually represented by the symbol "B" and measured in Tesla (T).
    • The length of wire in the voice coil within the magnetic field, often represented by the symbol "L" and measured in meters (m).
    BL = B × L
    A higher Bl value generally indicates a more powerful motor assembly, capable of generating greater force and excursion. Drivers with higher Bl values can exhibit better control over cone movement, improved power handling, and potentially produce higher sound pressure levels for a given input power.
    Main Page
      Posting comments is disabled.
    Latest Articles
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
    • Exploring Common DIY Terminology - SINAD
      by technodanvan
      SINAD (Signal to Noise and Distortion ratio)
      While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...
      26 July 2023, 07:41 Wednesday
    • Exploring Common DIY Terminology - Signal-to-Noise Ratio (SNR)
      by technodanvan
      The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
      The formula to calculate SNR in decibels is:
      SNR (dB) = 10⋅log⁡10(PowerSignal/PowerNoise)
      25 July 2023, 15:20 Tuesday
