Exploring Common DIY Terminology - Radiation Pattern
  • Exploring Common DIY Terminology - Radiation Pattern
    Radiation Pattern
    The radiation pattern, also known as the directivity pattern, is a graphical representation of how sound radiates into space. It shows the distribution of sound as a function of direction and is typically presented in polar coordinates. In the context of loudspeakers, the radiation pattern describes how the sound is dispersed from the speaker in different directions. It is important for understanding how a loudspeaker interacts with its environment and how the sound is distributed in a listening space. Different loudspeaker designs and configurations can have different radiation patterns, which influence the directivity and coverage of sound. There are several common radiation patterns and characteristics to look for in loudspeakers:
    • Omnidirectional: An omnidirectional radiation pattern means that the loudspeaker radiates sound equally in all directions. Omnidirectional speakers distribute sound uniformly throughout the entire 360 degrees around the speaker's axis.
    • Directional: A directional radiation pattern means that the loudspeaker concentrates sound in specific directions while reducing sound output in other directions. Directional speakers have focused coverage, which can be advantageous in certain applications, such as sound reinforcement in large venues.
    • Asymmetrical: Some loudspeakers have asymmetrical radiation patterns, where the sound output is not uniform in all directions. Asymmetrical radiation patterns are often found in line array speakers and are used to create specific coverage patterns.
    • Beamwidth: The beamwidth of a radiation pattern indicates the angular span over which the sound level remains within a specified range (e.g., -6 dB). A narrow beamwidth means a more focused, directional sound, while a wide beamwidth means a more diffuse sound.
    • Off-Axis Response: The off-axis response refers to how the loudspeaker's sound level changes as you move away from the central axis of the radiation pattern. Some loudspeakers have more consistent off-axis responses, while others may experience variations in sound quality and tonal balance.
    • Lobing: Lobing occurs when there are peaks and nulls in the radiation pattern, causing uneven sound coverage. Lobing is often associated with multi-driver loudspeaker arrays or poorly designed systems.
    Main Page
      Posting comments is disabled.
    article_tags
    Latest Articles
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
    • Exploring Common DIY Terminology - SINAD
      by technodanvan
      SINAD (Signal to Noise and Distortion ratio)
      While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...
      26 July 2023, 07:41 Wednesday
    • Exploring Common DIY Terminology - Signal-to-Noise Ratio (SNR)
      by technodanvan
      The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
      The formula to calculate SNR in decibels is:
      SNR (dB) = 10⋅log⁡10(PowerSignal/PowerNoise)
      25 July 2023, 15:20 Tuesday
