Exploring Common DIY Terminology - Baffle
  • Exploring Common DIY Terminology - Baffle
    Baffle
    A structure that surrounds and supports loudspeaker drivers, providing a surface from which sound radiates into a listening space. Some may discount the baffle as simply being the front of the speaker upon which drivers are mounted, however its purpose is varied and it can significantly impact the overall performance of a loudspeaker:
    • First, the baffle should be as rigid as possible to provide mechanical support for each driver installed and minimize unwanted vibrations or resonances.
    • Second, the size, shape, and material properties of the baffle will impact overall on- and off-axis frequency response by interacting with the sound waves generated by each loudspeaker driver, and can influence factors such as low-frequency extension, dispersion, and directivity.
    • Third, the edges and corners of the baffle can cause diffraction effects, resulting in changes to sound as it interacts with these boundaries. The shape of the baffle can help control and minimize these effects.
    • Fourth, integration with the rest of the cabinet influences structural integrity and rigidity of the cabinet, helping reduce vibrations and resonances.
    • Fifth, the baffle separates the front and back waveforms generated by loudspeaker drivers and can minimize or prevent interference and cancellation of the back wave on the front wave.
    • Finally, aesthetic considerations should not be ignored, as the front of the speaker will be what most people see.
    The design and implementation of a loudspeaker baffle requires careful consideration to achieve optimal acoustic performance, mechanical stability, and visual appeal.​
    Main Page​
      Posting comments is disabled.
    Latest Articles
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
    • Exploring Common DIY Terminology - SINAD
      by technodanvan
      SINAD (Signal to Noise and Distortion ratio)
      While not directly applicable to loudspeaker design, SINAD is a term in common use and is a valuable tool when comparing electronic equipment to match with your speakers. It can also be used when deciding what equipment you'd like to use for your measurement setup. SINAD stands for "Signal-to-Noise and Distortion ratio." It is a metric used to quantify the audio quality of electronic devices, particularly audio equipment like amplifiers...
      26 July 2023, 07:41 Wednesday
    • Exploring Common DIY Terminology - Signal-to-Noise Ratio (SNR)
      by technodanvan
      The signal-to-noise ratio (SNR) is an important parameter that helps evaluate the performance and quality of the audio output. In the context of audio, SNR refers specifically to the ratio of the desired audio signal (the sound produced by the loudspeaker driver) to the background noise generated by the speaker itself or the overall system.
      The formula to calculate SNR in decibels is:
      SNR (dB) = 10⋅log⁡10(PowerSignal/PowerNoise)
      25 July 2023, 15:20 Tuesday
