DIY Audio Community
Latest Articles
  • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
    by theSven
    By Jon Hancock
  • Cult of the Infinitely Baffled
    by theSven
    IB- F.A.Q.
    1)What's an IB?
    For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
    2)Which space is best?
    Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
    15 December 2024, 12:17 Sunday
  • Exploring Common DIY Terminology - Suspension
    by technodanvan
    Suspension
    The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
    • Spider: The spider, also known as the "speaker
    26 July 2023, 08:28 Wednesday
  • Exploring Common DIY Terminology - Surround
    by technodanvan
    Surround
    In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
    26 July 2023, 08:17 Wednesday
  • Exploring Common DIY Terminology - Spider
    by technodanvan
    Spider
    In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
    26 July 2023, 08:06 Wednesday
  • Exploring Common DIY Terminology - Soundstage
    by technodanvan
    Soundstage
    Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
    26 July 2023, 07:58 Wednesday
