Another Wavecor Ardent build
  • Another Wavecor Ardent build
    Finally the weather returned to reasonable temperatures and I'm able to get going again. Tries Ron's 80 grit on a piece of plywood method of flattening the top facet. Worked great except for nicking a corner and rounding it over. Would have been ally of sanding to fix, so I set up the vacuum rig. Veneer wrapped perfectly along the rounded edge until... Power outage. No power, no vacuum. My band clamps are 2 hours away. So I came up with this, hoping the bag and breather would provide some flexibility to get that round over wrapped.
    Click image for larger version  Name:	image.jpg Views:	826 Size:	98.9 KB ID:	925865
    Also used as much of Ron's veneer patching advise as possible. Epoxy bubbles aren't going to get wet. I used a heating pad with my caul on top to warm the veneer. It was much more flexible and the bubble seemed to want to be flat. Clamping by lead weights.
    Click image for larger version  Name:	image.jpg Views:	79 Size:	94.0 KB ID:	925866
    About half an hour after going out the power returned. Back under vacuum with clamps as a backup.
      Posting comments is disabled.
    Latest Articles
    • Breaking with modern conventions - a highly musical 2-way system using an 8" woofer
      by theSven
      By Jon Hancock
    • Cult of the Infinitely Baffled
      by theSven
      IB- F.A.Q.
      1)What's an IB?
      For purposes of this forum, an Infinite Baffle is a alignment where the drivers are free-air mounted, in a space adjacent the listening room. They fire into the listening area through a common opening between the two areas. This can be the attic, basement, or any room with shares a common wall with the listening area.
      2)Which space is best?
      Any space that provides a mounting location for the baffle, offers adequate volume for the IB, and
      15 December 2024, 12:17 Sunday
    • Exploring Common DIY Terminology - Suspension
      by technodanvan
      Suspension
      The suspension refers to the mechanical system that provides support and control for the diaphragm (cone/dome) and voice coil within the driver's magnetic structure. The suspension is an important component that allows the diaphragm to move back and forth in response to the electrical audio signal while maintaining stability and linearity. The suspension system typically consists of two key components: the spider and the surround.
      • Spider: The spider, also known as the "speaker
      26 July 2023, 08:28 Wednesday
    • Exploring Common DIY Terminology - Surround
      by technodanvan
      Surround
      In the context of loudspeaker drivers, the surround, also known as the "speaker surround" or "suspension surround," is a component that plays an important role in the driver's suspension system. The surround is typically a flexible ring or membrane that connects the outer edge of the loudspeaker diaphragm (cone/dome) to the driver's frame (basket). The primary function of the surround is to provide a compliant and flexible suspension for the diaphragm, allowing...
      26 July 2023, 08:17 Wednesday
    • Exploring Common DIY Terminology - Spider
      by technodanvan
      Spider
      In the context of loudspeaker drivers, the spider refers to a component that plays an important role in the suspension system of the driver. The spider is an essential part of the driver's overall mechanical structure, helping to center and control the movement of the voice coil and diaphragm within the magnetic gap. The spider is typically located between the voice coil and the frame (basket) of the loudspeaker driver. It is made of a flexible material, such as cloth or treated...
      26 July 2023, 08:06 Wednesday
    • Exploring Common DIY Terminology - Soundstage
      by technodanvan
      Soundstage
      Soundstage refers to the perceived spatial placement and localization of sound sources in a recording. It describes the three-dimensional presentation of audio, making it seem as if the sound is originating from specific locations within the listening environment, rather than coming directly from the loudspeakers. When a recording and playback system is capable of creating a convincing soundstage, listeners can experience a more immersive and realistic audio experience. The...
      26 July 2023, 07:58 Wednesday
