Rotel Rb981 urgent need help....
  • oliebato
    Hi i am new to this forum,I own a Rotel Rb 981,only one channel of my amp is working? Check all the connection,cables and everything seems to ok.I open the unit to check the fuse and the fuse are ok.Any help will be very much appreciated.Thanks to everyone..
    • 16478
    It sounds like you've already done all that I could suggest to do at home...which means your next option is really to take it to a repair shop and see if you can get a quote on what's wrong...unless its still under warrenty? ( I don't think it would be since it was made in '97 but it might depend on when you bought it)
    • gyusher
      RB981 For Sale
      by gyusher
      8O I want to sell my RB981 130x2/390x1 Mint, box, manuel less than 100 hours on it.
      Bougt new from a Rotel dealer in Gainsville, Florida (Sound Ideas) late in 2000. The amp set in the closet for almost 2 years in its sealed box.
      $375.00 delivered
      13 January 2003, 10:30 Monday
    • kmak
      RB981 @ a Hock Shop
      by kmak
      What's a good price for an RB981 used. Is it 130w per side or total. I'm thinking of offering no more than $400 CDN.
      Ken
      20 May 2004, 10:05 Thursday
    • jpmarotta
      Developing Issue: RB981 "whinning" on power-down
      by jpmarotta
      Hey all-
      Just a quick question before I send the unit off for service, wondering if anyone else has experienced this?
      On power-down, the left channel of my RB981 produces a mid to high pitched "whine" or "squeal" about 5 seconds after the protection...
      27 December 2005, 12:05 Tuesday
    • kingwilliam
      RB-991 keeps blowing main fuse
      by kingwilliam
      Hi all...
      The problem: My RB-991 blew its main 12-amp fuse the other day (the fuse you can easily change from the back). I tried 10-amp fuses, but blew three in a row. No other components or speakers were hooked up to the amp. I unplugged the amp from the wall before swapping fuses....
      16 December 2009, 21:23 Wednesday
    • sam500
      Rotel RA-02: Blown fuse
      by sam500
      I stupidly blew a fuse in my RA-02 amp. I've taken off the cover, located the fuse in question and just wanted to make sure that the new fuse I have bought has the right spec.
      The RA-02 takes a T4A 250v fuse. I've just picked up a '4A 250v' fuse. How important is the T ?! Will the 4A...
      21 January 2007, 04:05 Sunday
