Can anyone tell me if the speaker size and sub crossover settings apply when the Multi Input is used for DVD-A for SACD? A little confused after reading the manual........
Also, I have two subs. I was advised to use just one and hookup to LFE / Sub output. I am thinking about going back to my original configuration of using the sub in between the pre pro and power amp and using the second sub as LFE.any comments on this????? I presume I'd set the fronts to Large in this case (if it matters with the Mult Input>>.)
thanks
Mike Conover
thanks
Mike Conover
