Has anyone noticed this? It's to the left of the "EX" light. Anyone have a theory on why it's there?
THX Sur LED on 1066's front display
Chances are it's a cost saving maneuver. Instead of creating a separate display for each product, they create one, and only "wire" in the things that are relevant. This is done a lot in the auot industry with guage clusters. If you look closely, or use a flashlight to light the cluster (helping you to see the icons when they are not lit) you will see things that are not part of your car. For instance, some vehicles come with Traction Control, while others don't. The icon will be there, but no circuit is connected, and no bulb is present.Originally posted by wngHas anyone noticed this? It's to the left of the "EX" light. Anyone have a theory on why it's there?
OR, maybe it's there in case ROTEL decides to get the unit THX certified. I'd bet they could enable it through software. Why spend the money redoing the display, when you can just turn it on in the firmware if need be.
$0.02
-Thomas-
The easiest way to find something lost around the house, is to buy a replacement.
Hey You! Make sure you stop by the HTguide Off-Topic section. It's FUN!!!
-Thomas-
As long as people will accept crap, it will be financially profitable to dispense it.
Hey You! Make sure you stop by the HTguide After Midnight section. It's FUN!!!- Bottom
Thomas, I thought that too, the use of common components to save on costs. I was also thinking that was a sign that the 1098 was going to get THX certified. But now, we know the 1098 doesn't use that smallish display, hehe. Maybe the 1066's successor will get THX certified?- Bottom
You're probably right. The 1098 is most likely ROTEL's move into the next "price point" or so. It's not meant to replace the 1066, but give current 1066 owners an upgrade path.Originally posted by wngThomas, I thought that too, the use of common components to save on costs. I was also thinking that was a sign that the 1098 was going to get THX certified. But now, we know the 1098 doesn't use that smallish display, hehe. Maybe the 1066's successor will get THX certified?
Maybe there is going to be a 1068, or 1078 or something like that, a couple of quarters after the 1098 is released. Or maybe the next rev. of the 1066 will get the cert, and they can simply toggle that light.
Who knows?
-Thomas-
-Thomas-
I asked Rotel over a year ago about the dark "THX" indicator on the display. They said they have no plans to play the licensing fees necessary to add THX processing to the 1055/1066. It was put there "just in case" circumstances changed and it became necessary. But, given the 1055/1066 do Rotel-XS, DD-EX, DTS-EX and DTS-ES, there really is no need to add another rear channel processing scheme.
Gregg- Bottom
When the 1066 was constructed It seemed that you can only get EX Surround Decoding with THX or that this feature will be called THX Surround EX.
Now it is available as Dolby EX without THX.
But the display was already designed.
Thats the story I heared and it seems logical to me. In the beginning of EX many machines called it Dolby 6.1 Matrix e.g. and there was no logo available. (Denon 3802 e.g.)
Left forum because sold Rotel gearMats
Mats Strömberg
Ah! It's a profit deal! Takes the pressure off! Get your weight guessed right here! Only a buck! Actual live weight guessing! Take a chance and win some crap!
Navin R Johnson (alias Steve Martin)- Bottom
by Andrew PrattTwo Digital Amplifiers Achieve the THX Ultra2 Criteria for Audio/Video Receivers
SAN RAFAEL, Calif.* December 14, 2004 -* THX Ltd., the leading provider of technologies, certification programs and quality assurance standards for the entertainment industry, today announced that two digital amplifiers... -
by LexmanToday, I sort of felt a little rough, and stayed home. I took the opportunity to disect my MC-1 and perform the long awaited EX upgrade, which I have had for a couple of months. Well, the second upgrade, that is. My first intallation way back in the summer I guess, or was it spring, failed miserably....15 November 2000, 18:16 Wednesday -
by Chris DThis press release was posted today by Parasound's PR agency at this website--follow this link for more pictures and individual component press releases as well.
http://www.gspr.com/parasound/newclassic.html
Channel: Club Halo/Parasound
by ZzapI'm sorry I missed this Q&A session
I wanted to hear what their stand was on THX certification.
I know that they've had products certified in the past but it seems that they've stopped certifying newer products - my RMB-1075 is certified, my RSP-1098 is not.
Channel: Club Rotel
by JonMarshI had a very pleasant experience last night, watching an above average new release at my local Regal Cinema, and it got me thinking about somethings which for me sum up my misgivings about conventional HT think and I like to approach some of the home viewing goals from a different perspective and set... - Loading...
- No more items.
