HELP, my RMB-1075 is dead 8-(
  • jalyra
    • Jan 2009
    • 43
    A few days ago the power at my home just went off, back on in a few seconds, then off and on like three or four more times in just a couple of minutes. After that my RMB-1075 became short circuited I had to turn the power from the amp off since I had it activated by the 12V trigger because after the power stabilized at my home the power amp was turning on an off intermittently.
    I had a technician take a look at my amp and it seems the main problem is the toroidal transformer and it has to be replaced, my question is how can I buy a new one? Do you know where can I order one? it would have to be shipped to Guadalajara, Mexico since that's where I live.
    Any help would be greatly appreciated.
  • madmac
    • Aug 2010
    • 3122
    Poor you....sooooo...sad!!. Very unfortunate to say the least!. Did you have it hooked up to a spike protector?. Anytime a storm or some kind of electrical disruption happens, I immediately throw the main power switch off on the back of my Rotel and disconnect the power cord.
    I would contact Rotel directly about getting a new transformer if the technician you have can install it for you. If not, you can always send it back to Rotel and have them repair it.
    Dan Madden :T
    • jalyra
      • Jan 2009
      • 43
      I actually had it hook up to the RLC-1040. It was strange because the fuse didn't blow up, and the protection circuit was somehow bypassed. I'm definitely going to contact Rotel.
        I sent you a PM on who to contact.
        • jalyra
          • Jan 2009
          • 43
          Thanks a lot Dan!!!
          • Kasper
            Humming from the power transformer JC-1
            by Kasper
            One of my JC-1 have a humming from the power transformer. When I go from 10watt to 25watt the humming increase a little more. I can hear the humming
            1 1/2 meter (60 inchs) from the JC-1.
            The other JC-1 is 100% silent. Is this normal with some humming, or shall the transformer be 100%...
            14 April 2006, 12:57 Friday
          • Allan
            RMB1095 Pops at Power Up/Off
            by Allan
            I've a RMB1095 amp that pops through the speakers (all) during both power up/off. I've tried cleaning all earth pins on the cables and are at a loss.
            I've visited the Rotel internet site looking for an email address to email Rotel to see if they cant shed some light, but they dont seem...
            06 January 2005, 20:06 Thursday
          • Burke Strickland
            Parasound introduces new Halo JC1+ monoblock power amplifier
            by Burke Strickland
            https://parasound.com/jc1+.php
            Replacing the original John Curl-designed JC1, which was chosen as a “Category A Recommended Component” for 15 years by Stereophile’s editorial staff, Parasound has just introduced the JC1+ monoblock power amplifier, which was also designed...
            24 January 2020, 22:16 Friday
          • Eric S
            133v out of balanced power transformer?!?
            by Eric S
            Hey Guys,
            As my basement theater is coming closer to completion, I need to build a power filter/sequencer for all of my gear. So now I've got a box, a bunch of EMI/RFI filters, a pile of heavy duty relays, and some delay timer circuits from Apogee.
            The sequencer will have...
            25 March 2011, 07:54 Friday
          • cdwitmer
            Can I get the benefits of balanced power with a pair of these transformers?
            by cdwitmer
            I have located a supply of cheap 2kVA transformers that have single 100V primaries and dual (bifilar wound) 24V secondaries. (Each of the secondaries is indicated as 42A.) I know I could tie two of these back-to-back to create a 1:1 2kVA isolation transformer, but I am wondering if there is a way I...
            23 September 2005, 02:08 Friday
