Need help with RSX1065
  • bcolley
    • Apr 2011
    I moved my receiver into another room and hooked all the speakers up. I have a 2.1 set up. The sub works fine but the front speakers don't work at all. I have it set to optical 1 input with PCM 2ch output. I feel like this has happened to me before when I was setting it up and I had to mess with the settings, but I can't remember how I did it. Anyone have any advice or know of this issue?
  • madmac
    • Aug 2010
    • 3122
    First, double check that the toslink is properly connected on both ends and to the correct input on the Rotel. If so, go to Menu/inputs/ toggle through and select optical 1. Make sure that all the correct speakers are set to small/large/ and in your case....OFF for the center/ surrounds. And of course, the sub is selected as YES.
    Let me know if that helps you?
    Dan Madden :T
    • madmac
      • Aug 2010
      • 3122
      I hope he/she is ok?. I hope the Rotel didn't blow up or something!!??? Hehehe!!
      Dan Madden :T
      • Erik
        choosing rsx1065 over rsx1055
        by Erik
        Hello all, this is my first post here.
        Lots of topics to read, but i read it to juni so far :-)
        I have still one question. My situation:
        room - 4x6 meters
        speakers - now 2 x matrix 805 (hopefully, one day 5 x matrix 805)
        I listen 50% to Music:
        25 October 2003, 18:25 Saturday
      • eponies54
        RSX1065 market price?
        by eponies54
        Currently own a Denon AVR3802 and am considering the RSX1065.
        I have a friend who is selling his black faced rsx1065 and we are not finding fair market value prices. Anyone have a link or possible price he and I might agree on?
        My understanding is this is mint condition with all the packaging...
        10 November 2006, 20:21 Friday
      • RobP
        RSX1065 Display issues
        by RobP
        I have a problem with the display on my RSX1065, when I go to adjust settings such as the sub level or center level, the display fades somewhat and it is hard to read. :scratchhead: Has anyone else had this problem? If so, what was done to remedy the situation?
        Thanks!
        Robert...
        26 April 2005, 09:37 Tuesday
      • sirbogey
        CS DAC in RSP 1098 & optical digital MacBook
        by sirbogey
        Is it correct to assume that my MacBook can be hooked up to the RSP 1098 thru optical digital (Toslink to MiniPlug) wire and the sound will be directly decoded thru 1098's Crystal Semiconductor's 24 bit/192kHz DAC without the need of another external DAC.
        any thoughts. :T
        09 March 2009, 13:00 Monday
      • gshisme
        Optical vs. coaxial digital for the 1066
        by gshisme
        I have been using digital optical cable for both my DVD and HDTV satellite receiver to connect to the 1066 and my dealer yesterday told me to throw away my optical for coaxial. Huh? Everything I have read points me to optical cable. Any comments on optical vs. coaxial cable use.
        Greg...
        26 May 2003, 13:31 Monday
