RSX 1065 Power Cord Specs
  • Blues
    • Feb 2011
    • 20
    I bought my 1065 lightly used a number of years ago and have never been comfortable with the power cord. It doesn't fit very well in the power port and has 3 holes on the female end, even though it only needs 2.
    Any other 1065 owners out there have similar findings and what guage is your power cord? Mine is 16AWG and I just want to make sure I have the correct one.
    Thanks!
  • madmac
    • Aug 2010
    • 3122
    I have a 1067 and the power cord is indeed 16 guage and 2 prong....both at the male and female sides. Important to plug this unit into a spike protected power bar!!
    Dan Madden :T
    • Blues
      • Feb 2011
      • 20
      Interesting, wonder why my power cord is a 3 pronger? Thanks for the info!
      • Glen B
        • 1106
        Either the cord came with the unit or the previous owner switched cords. I suspect the latter. Nevertheless, a 16 gauge cord is rated to 1,560 watts, and is adequate for your Rotel, which has a 550W power consumption rating. I've seen captive 16 gauge power cords on amps of 200 and 300 watts per channel. No problem using a three-pin IEC plug in a two-pin inlet.
        • Blues
          • Feb 2011
          • 20
          Thanks!
          • RoMan
            Rotel 1565 power cord issue
            by RoMan
            Quick question. What is the best way to secure the power cord in the socket of my Rotel RMB 1565 amp? Everytime I need to move my cabinet the power cord seems to lose contact with the socket and the amp shuts off. I'm finding I need to turn off the amp, and then reach in and push it in to get a good...
            01 August 2012, 18:20 Wednesday
            Cheap way to power an amp on/off
            by Andrew Pratt
            I have two power amps one has a built in power off and on toggle that my pre amp controls but my Class A Musical Fidelity amp does not. Given the Class A design this amp is sucking a lot of current from the wall and I wished I had a way to turn it on and off without resorting to an X10 switch or some...
            17 February 2002, 19:15 Sunday
          • Ron Reda
            1066 Power cord replacement
            by Ron Reda
            Based on some discussion in another thread, I went ahead and ordered a VH Audio Flavor 3 power cord to replace the stock cord that came with the 1066 pre/pro. However, when it arrived today, I noticed that the cord had a three-prong female receptacle with a three-prong male receptacle versus a two-prong...
            26 August 2003, 18:43 Tuesday
          • Russ L
            Upgrade Power Cord for RB-1070?
            by Russ L
            The RB-1070 only has a 2 prong female outlet for the power cord (while the RB-1080 has a 3 prong). If I want to upgrade my power cable does anyone know a brand that supplies a cable that will fit? I've searched everywhere to no luck. I hope Doug doesn't mind the question since he doesn't sell power...
            30 July 2007, 17:08 Monday
          • xspale
            Rotel 1065 Buzzing Problem
            by xspale
            Hi Everyone,
            I am new to Rotel and this forum. Before few weeks I purchased Rotel 1065 A/V Receiver from 2002.
            If I am close to speakers I can hear silent buzzing sound from left speaker. I have tried to disconnect everything and switch to fm tuner but buzzing is still there....
            07 January 2009, 04:14 Wednesday
