AppleTV audio setting w/RSX1067
  • BW4me
    • 75
    I just got the new Apple TV to try out with my RSX-1067. I have it hooked up through the optical input.
    What is the best audio setting I should set for the default on my rotel? Right now it's set to 2CH PCM, but not sure if there is a better choice. Mostly, I would just listen to music and sometimes a movie.
    Also, if default is set to 2 channel and then you watch movie through Apple TV does it automatically receive and play the 5.1 soundtrack or would you need to manually select it.
    Thanks for the help
    Steve
  • BW4me
    RSX-1067 with AppleTV (5.1 problem)
    by BW4me
    I'm using the optical output from my Apple TV 2 for the audio connection to my RSX1067. I have never been able to get sub audio with 5.1 movies played from netflix or iTunes rentals. The same audio input on my rotel will play 5.1 from DVD or BD player. I can also play 5 channel audio from iTunes...
    19 September 2011, 16:20 Monday
  • BW4me
    Problem playing 5.1 with AT2 on Rotel RSX1067
    by BW4me
    I'm using the optical output from my Apple TV 2 for the audio connection to my RSX1067. I have never been able to get sub audio with 5.1 movies played from netflix or iTunes rentals. The same audio input on my rotel will play 5.1 from DVD or BD player. I can also play 5 channel audio from iTunes library...
    19 September 2011, 16:23 Monday
  • cinema bob
    apple TV
    by cinema bob
    very cool new tool from apple the apple tv
    http://www.apple.com/appletv/...
    09 January 2007, 15:02 Tuesday
  • Parrot Head
    1066 Default Setting
    by Parrot Head
    I need to ask what may be a dumb question about the 1066’s Default Setup. I’ve been adjusting the rear channel settings via the remote to approx. +7dB. I find this (although it may be a bit exaggerated) improves the surround experience when listening to basic cable.
    My problem...
    07 May 2003, 08:33 Wednesday
  • sokoban
    iPhone and appleTV
    by sokoban
    So, anyone else see the new stuff announced at Macworld?
    iPhone
    4 and 8 gb models
    full widescreen/touchscreen ipod
    802.11 built in
    runs OS X applications
    appleTV
    Plays media from iTunes (H.264, AAC, MP3, apple lossless, aiff)
    720p...
    09 January 2007, 15:05 Tuesday
