RSX-1067 with AppleTV (5.1 problem)
  • BW4me
    • 75
    I'm using the optical output from my Apple TV 2 for the audio connection to my RSX1067. I have never been able to get sub audio with 5.1 movies played from netflix or iTunes rentals. The same audio input on my rotel will play 5.1 from DVD or BD player. I can also play 5 channel audio from iTunes library (with sub).
    Apple tell me my AT2 is working fine so must be my receivers setting. Am I missing something? Didn't think this should be so complicated. It sounds like a software problem with AT2 but I don't know.
    Anyone have suggestions for what my audio setting should be on the rotel?
    Steve
  • Dmantis
    • 1037
    Go into Setting andy make sure Digital out is on Auto. This will give you exactly what is being played from the Apple TV 2. It is a replay device and can only do what you tell it to do.
    • BW4me
      • 75
      Yes, I've tried both the "on" and "auto" settings for the Dolby Digital out on my Apple TV2 and neither make a difference.
      I don't understand as much about types of digital signals, but from what I've read on an Apple forum on this subject others with different avr's have had smiler issues. There seems to be the opinion that ATV2 doesn't send signal in format that is recognized as DD5.1 or DTS5.1 by some avr's. So maybe it's a software issue with Apple.
      My Rotel manual says that it automatically will detect these signals and activate the correct processing but for some reason it never does with ATV2. My Rotel display continues to read "Dolby Pro Logic". Rotel won't let me manually select that setting.
      • BW4me
        AppleTV audio setting w/RSX1067
        by BW4me
        I just got the new Apple TV to try out with my RSX-1067. I have it hooked up through the optical input.
        What is the best audio setting I should set for the default on my rotel? Right now it's set to 2CH PCM, but not sure if there is a better choice. Mostly, I would just listen to music...
        19 October 2010, 12:00 Tuesday
      • BW4me
        Problem playing 5.1 with AT2 on Rotel RSX1067
        by BW4me
        I'm using the optical output from my Apple TV 2 for the audio connection to my RSX1067. I have never been able to get sub audio with 5.1 movies played from netflix or iTunes rentals. The same audio input on my rotel will play 5.1 from DVD or BD player. I can also play 5 channel audio from iTunes library...
        19 September 2011, 16:23 Monday
      • cinema bob
        apple TV
        by cinema bob
        very cool new tool from apple the apple tv
        http://www.apple.com/appletv/...
        09 January 2007, 15:02 Tuesday
      • sokoban
        iPhone and appleTV
        by sokoban
        So, anyone else see the new stuff announced at Macworld?
        iPhone
        4 and 8 gb models
        full widescreen/touchscreen ipod
        802.11 built in
        runs OS X applications
        appleTV
        Plays media from iTunes (H.264, AAC, MP3, apple lossless, aiff)
        720p...
        09 January 2007, 15:05 Tuesday
      • Armbender
        DACMagic with AppleTV
        by Armbender
        Anyone have any experiences (good or bad) with this set-up...Im looking to add an external DAC to my AppleTV and the DAC Magic certainly fits the price range and the reviews seem really decent...
        I plan on running optical from Apple TV to Dac, then Analog from Dac to reciever for 2ch...
        03 December 2009, 10:46 Thursday
