Can anybody tell me if this is normal..?When I use my sub and use the crossover filter in the RSP1098 the sub makes a popping sound every time the RSP1098 clicks from dolbydigital to 2ch and back, and when I change the input from cd to tuner and other settings?
I might have a problem with my sub and RSP1098
by sirbogeySetup since yesterday: RSP-1098, RMB-1075, and RDV-1060 with catcables (just received, they are awesome); 2 fronts, 2 rears, 1 center, 1 sub (all speakers are Piega). I installed the most recent upgrade on the 1098 as well and then set to default settings.
Cables are definitely connected...-
Channel: Club Rotel
by Briz vegasI posted this experiment in the Home Theater section but no comments so I thought I would try here. This is where the guys with some technical know-how hang out.
I have a popping problem with my REL Strata 5 Sub - 10inch driver, 150w amplifier, downward firing, sealed box of modest size...-
Channel: Mission Possible DIY
by edcroteauAdvice needed desparately.
My subwoofer is rumbling and popping, even with no signal at all.
I've got a Velodyne SPL-1000 II, a Denon 3805 AV/R, B&W speakers, and other components that seem unrelated to my problem.
I've hooked up the sub directly to the...-
by DrBoomJust got my first 2 Rotel components, namely an RSP1098 and an RMB1075.
Very happy with both, even though they are severely being limited at the moment by my cheap Yamaha speakers which will be replaced with B&W (800 or 700 series) very soon.
Only 1 thing i can't get to work, the speaker...-
Channel: Club Rotel
by sarsiI like to share some of recent experience with my new 3D TV setup with my current Rotel RSP1098/RMB1095 setup. I am hoping this information is useful for anyone with the same configuration out there that are interested to take the 3D plunge.
I had not been very active in the last couple...-
Channel: Club Rotel
- Loading...
- No more items.
