1068/1075/1080 power source question
  • PSUfan
    • 80
    I just added the 1080 to power my mains in my home theatre setup. I have an H10 APC power conditioner. I can set the H10 to power up each unit seperately. Do you think that this will work, or will I be blowing fuses?
    I will also have my dvd player, satellite box, and and Sony 46" LCD plugged in. Any thoughts?
    Shane
  • joetama
    • 786
    It always scares me do drop power out on an amp or any audio product that isn't made to do that....
    -Joe
    • PSUfan
      • 80
      I'm not sure what you mean could you explain?
      Shane
      • Kevin D
        • 4601
        Your biggest chance of blowing a breaker is at turn on as that's usually when it draws the most power. I would trigger the 1080, then 1075, then everything else.
        Kevin D.
        • RisBo
          rb1070 or 1080 with 1075, need help
          by RisBo
          Hello
          I have 1066+1075 to power 805S,htm-4s and soon two pairs ds7.Everything below 80hz to sub.
          In general people ad 1080 to give more power to their full-range fronts but what if I with 1075 power up fronts and surround back and use 1070 for surround left and right. Is this good combination?...
          29 December 2005, 06:39 Thursday
        • haiuy
          Rotel RB 1080: RMB 1075: or B&k Ref 200.2
          by haiuy
          Hi all,
          Just purchased the Rotel RSX-1055 and planning to add separate 2ch or 5ch amp. Im looking to spend $800-1100. I've narrowed down my choices to the Rotel RB 1080 (2x200w $1000), RMB 1075 (5x120w $1000) and B&K Ref 200.2 (2x200w $1300) msrp. I listen to 60/40 music/movies....
          01 October 2003, 21:34 Wednesday
        • Claw
          RSX-1056 vs RSP-1098+RB-1080+RMB-1075?
          by Claw
          Hiyas everyone.
          I found this place about a month ago but I've just been lurking. Finally decided to unmask myself and ask a few questions.. hopefully not too stupid I'll get laughed at.
          I recently purchased a RDV-1040 DVD player to go along with my new TV, a Toshiba 34HFX84...
          02 April 2005, 02:34 Saturday
        • doodleboytoy
          1080 or 1075 for a 1055 receiver
          by doodleboytoy
          Setting up a 5.1 system using a 1055 receiver. Which amp would do a better job - 1) the 1080 driving the fronts and the 1055 driving the center, surrounds and maybe in the future side surrounds (is that possible?). or 2) 1075 driving all five channels and maybe the 1055 driving the side surrounds in...
          29 July 2003, 22:53 Tuesday
        • shadow
          RB 1080 or 1075?
          by shadow
          I am thinking of adding one of these amps to my 1056 to drive my front speakers (ML Aerius i and Cinema). I have participated in the threads in which the 1080 is favored over the 1070 stereo amp. However, since the center channel is the most important channel in HT or multi channel music, I would...
          27 September 2004, 16:49 Monday
