Hi there, first time at posting.
I live in Australia and am having a huge problem finding an audio rack capable of both fitting in and supporting my components.
The system is still under development but currently I possess the Rotel Rb1090 and the RMB1095. Waiting for the new lineup of Rotel gear ( RSP1098 replacement inclusive ) but envisage having all the source and processing equipment as Rotel. Problem is, with the dimensions of the two above-mentioned amps, no rack I have found has the shelving high enough to support the height of the two Power amps, let alone their weight. When I do eventually have all the equipment I was after, the rack will probable need to be about six shelves in dimension and able to support a combined weight of about 110kg ( 240lb ).
None of the racks I have seen or enquired about so far can fit all the proposed items, in particular the amps. If anyone has found a brand or solution that can achieve all of this please let me know.
Regards to All !
Regards to All !
