RSX1055 stuck in zone 2 ... help please
  • hdtvjim
    My rsx 1055 was working fine 2 days ago. Turned in on today and it's stuck in zone 2. No display excpet for zone light ...
    No audio from fron
    Hitting the zone button actually toggles the power on and off !
    I re-flashed with the latest software and have the same results.
    Is there a hardware reset sequence other than re-flashing ?
    Any help appreciated ....
    • 16478
    Yes do a factory reset in the menu. If that doesn't do it call your Rotel dealer and have it looked at.
    • hdtvjim
      Stuck in zone 2 ... help
      Can't get to the menu to do the factory reset.
      Nothing is displayed on the video monitor or on the front panel display except the zone light.
      If you press the zone button and then hit a source that works. If you hit the zone button again, the rotel power toggles on and off.
      Thanks ...
        • 16478
        Ah that would be a problem! Take it back to the dealer.
        • dallaskruse
          Rotel 1066 - Zone 2 - Remote Control
          by dallaskruse
          Products: Rotel 1066 and RR-969 remote Control
          I am at the tail end of adding a Logitech Harmony to my parents' Home Theater.
          They have a Rotel 1066 receiver along with the Rotel RR-969 remote.
          Zone 2 works great when accessed via the front Zone button on...
          19 October 2014, 09:59 Sunday
        • aredant
          RC-418M remote locked up, won't reset.
          by aredant
          I have a RC-418M remote control that I use with my DTR7.1 receiver.
          It's not unusual to accidentally press the wrong keys, but this unit seems to be stuck in limbo mode. It was stuck with the display "M-09". Could not cancel out. I followed the directions to reset. Hold down ON/RESET...
          10 January 2010, 16:48 Sunday
        • starford
          Figured out Zone 2 operation on C 1
          by starford
          Well, I finally figured out how the Zone 2 thing works on my C1. I reported earlier that operation of Zone 2 appears to be impossible from the front panel, because pushing the Zone button appears to do nothing but show the message "Zone Off", and in this I was wrong. The change I was missing...
          22 September 2003, 11:05 Monday
        • FLAK
          RSX-1067 - Zone 2 Issue
          by FLAK
          Hi Rotel Club,
          I recently purchased Rotel's RSX-1067 - and could not be happier with the upgrade in audio quality!!!
          With that said - there is one frustration :x - that I have not been able to resolve. I can not get Zone 2 (my backyard) to work correctly. I have read...
          27 June 2005, 22:56 Monday
        • njarwala
          RSX-1560: Using CB Amps for Zone 2
          by njarwala
          I have a Rotel RSX 1560. My setup is 5.1 and I do not have Center Back speakers. I want to configure the receiver so that I can use the two Center Back amps to power speakers in my backyard - as Zone 2. I can't seem to get it to work.
          Here is what I have already...
          04 May 2012, 21:54 Friday
