I have heard a lot about NOT plugging your power amps into a line Conditioner. So when my 1075 arrives, I shouldn't plug it into my Panamax conditioner?
I have 2 dedicated circuits running into my livingroom. The Pioneer TV, pre/pro, dvd, cd, and clr2500 def tech powered center all plugged into the panamax thats running off the 20 amp line. And I thought I was doing the right thing by leaving the other Panamax thats connected to the 15amp line, empty, ready and waiting for the 1075.
If I don't use the conditioner, and plug it directly into the socket, I'll be worried about any surges/spikes, unless the amp itself has some sort of protection against this.
The amp will be arriving Wednesday(tomorrow), so any help is greatly appreciated. I was thinking about getting a 2 outlet "Brick Wall" protector to use for the amps, looks like I might have to do that afterall. Heres the item I'm speaking of... http://www.pricewheeler.com/prod2r.htm It's for high power amplifiers.
How do some of you have your amps plugged in?
By the way, my conditioners are the cheaper Max 4300's. 3 Unswitched outlets, and 4 switchable. I have always had the components that draw more power plugged into the unswitched ones.
Thanks in advance for any advice!
Life is short, Play it LOUD!
Have a good one, and again, thanks for the input.
