Hello All,
I haven't been very happy with the sound from my setup, so as a last ditch effort (because I just didn't want to believe the problem is my 1067), I tried connecting a 500 Euro Yamaha receiver and, rather unfortnately, it sounded considerably better than my considerably more expensive Rotel setup.
Compared to the Yamaha, when I use the Rotel gear I have low volume and low bass and while everything that I hear sounds accurate, it sounds somewhat muffled as well.
I have the following setup -
Rotel DVD 1050-E
Rotel 1067, only the two front speakers are connected zone 1, left front and right front.
Pre-amp left front and right front outs go to a Rotel 1080
The cables are all Monster
The speakers in place at the moment are Infinity 9.2i Series II, with the 1080 on the bass and the 1067 on the highs.
I've tried using just the 1067 in a non-bi wired configuration.
I've tried the 1067 with JM Labs Cobalt series.
I've tried using the Yamaha CD player that I used when I tested my speakers with the Yamaha receiver with the Rotel 1067.
I've tried analog with multi-input versus digital into video 1 (PCM 2 channel).
I've tried playing with the crossover settings for the speakers in the 1067 setup.
Nothing seems to make any difference in the problems I'm having, and it seems to point to the 1067.
Any suggestions that you have are most welcome -
Lars
Rotel DVD 1050-E
Lars
