I have been using for digital cable a Motorola HD receiver from Comcast, and had no audio problems on either digital or analog/standard channels.
I have now upgraded to the DCT6412 series HD Dual Tuner Receiver with DVR capabilities. I have had the following problem, with two different units. I have changed nothing on the Rotel side:
I only get audio on the digital channels, but not the analog channels!! I have tried the the optical digital audio and the coaxial digital outputs. The "dolby" red lettering on the Rotel is flashing and I can hear some crackling in the speakers.
It's as if the audio signal is losing strength on the analog channels.
Anyone heard of this and/or know of a fix?
Thanks in advance.
Thanks in advance.
