Well this is the second microphone in a row that is bad, this time it went bad after the first use. The first one was bad out of the box, this one worked just once, turned it off, put it away, got new furniture so I went to redo the auto calibration and it would work for the Level setting (barley) but wont do the distance settings at all, keeps saying too much variation. The distance readings are all over the place, first reading will be 10, the next will be 50. I tried moving the mic closer and it worked, it seems that the mic sensitivity has changed since last use. I read a professional review where the author stated the same problem with the mic, he mentioned that you should not leave the battery in the mic after use, even in the “off” state it seems like the battery will somehow ruin or degrade the mic filament over a short time.
I wonder how many of you have tried to use your mic again after the first cal, I'll bet not many. I think there is a design flaw in these mic’s and most wont see the problem as they just do the cal once and never again.
