A51/A52 continuous AC Power
  • Chucka
    • Aug 2009
    • 28
    The owners manual for the HALO A51/A52 says that these amplifiers require "AC that is continuous rather than switched on and off".
    Does anyone know why this is and what would happen if one were to use a product such as one of the new GREEN Power Conditioners which switches off all outlets when not in use. What problems will this cause if any? I always try to keep all my power usage to a minimum which is why I switch all of my "wall warts" off when not in use (most on computer system) and would like to do the same with the use of these amps.
    Chucka
  • Peter Nielsen
    • 1188
    You can safely use a power conditioner that swiches off the outlet as long as the conditioner is designed to handle power amps.
    However, one minor issue: The HALO amps have a "soft power button". If power is switched off to the amp, it will (as far as I remember) require that you manually turn on the unit by pressing the power button on the front of the unit.
    You can work around this problem by using the 12V trigger to start the amp. For instance if your preamp or power conditioner has trigger outputs, this should solve the problem.
    • Chucka
      • Aug 2009
      • 28
      This is the info I was looking for. Thanks!
      Audio sensing will not work unless a circuit stays alive to sense the audio, thus requiring constant power to the amp. So the answer to my desire for a total power down is the use of the 12V trigger once the AC is back on.
      I will also watch to make sure the power conditioner output to the amplifier is rated at 15 Amp.
      Thanks for your help.
      Chucka
      • Eliav
        Are your amps. plugged in directly to the wall Vs power conditioner ?
        by Eliav
        Hi All
        Has any of you experienced any audible diffierences ( particularly in lower frequencies reproduction) , when powering your amps through your power conditioner Vs the walls outlets ?
        My experience with Classe CAM 600 monoblocks is that Bass reproduction is slightly...
        13 May 2012, 13:28 Sunday
      • BWLover
        Power Conditioner/Voltage Regulator
        by BWLover
        Hi there everyone! I recently had my stuff moved out of storage from another province to the province I moved to three years ago, it's so nice to have my stereo back. I've got a quick question about my power conditioner. At my old place the power coming in was pretty stable at 120V, every once in a...
        10 July 2016, 10:38 Sunday
      • jeweltone2002
        A51 transformer hum...Need power conditioner?
        by jeweltone2002
        I recently purchased the A51, and I am getting a hum from the transformer. The hum comes directly from the A51 unit and not through the speaker (it's not a ground loop problem). I send the A51 back to Parasound for repair and they replaced the transformer (very good technical support...
        04 November 2004, 00:06 Thursday
      • spykids777
        Power Conditioner and Classe Amp
        by spykids777
        I have Classe CA5300 and 2 CAM 600 amplifiers and the SSP-800. I have noticed that depending upon the type of music or movie that I am watching my blue LED lights on the Amp start blinking (not blue and red). Currently I have them hooked to a Panamax 5100 power conditioner. Do I need...
        18 July 2011, 08:32 Monday
      • georgev
        Power Conditioner for Projector
        by georgev
        My projector comes down through a bulkhead(dropped ceiling), and gets its power from a plug inside the ceiling.
        Is there any product that offers a single outlet power conditioner that I can use there?(e. PS Audio used to make a Ultimate Outlet). They make the soloist in wall conditioner but only...
        19 May 2007, 03:00 Saturday
