Hi guys!
This is my first post here in HTguide. I've been reading the forum for a while and thinking about step into seperate by adding amp before next generation comes up(so I can afford upgrading one by one).
I'm considering about getting Halo A23 or NewClassic 2250(or Halo A21 even) for the front channels upgrade. My question is: The higher power rating would produce more detailed sound, but what if the listening volume is very low? My front speakers are Klipsch RB-5II that has 96db @ 1watts @ 1meter. As my setup locates in my bedroom that I never crank up the volume higher than 85db or so. In other words I will never use more than 1watt out of the ampflier. Would I get better detail out of NC 2250 or A21 over A23 at these low volume? And the difference would worth the money or not?
Thanks in advance!
Thanks in advance!
) But this way would only allow me to place the floorstanders as main by then, no more bookshelves are possible(unless i spend extra couple hundreds on the stands).
ops: )
