Sound difference between DM600s3 and DM601s3??
  • biomed_eng_2000
    • 18
    Besides the obvious bass extension difference, what are your opinions of the sound difference between the DM600s3 and DM601s3??
    Since they are only about $50 difference in price, that is somewhat irrelavant to me.
    I want to get the one that has the most accurate midrange since it will be crossed over at 100Hz to a 10" subwoofer. The 601 or 600 will thus be playing 100Hz (via 24db/octave crossover) and above.
    THANKS!!
  • Aussie Geoff
    • Oct 2003
    • 1914
    I'd take the 601 S3 every time. Your $50 will get you a 50% heaver box (= better construction / less vibration), better power handling and for analogue stereo listenning (when you probably won't have the sub) at least some bass response. Also even with the sub you need to remember that the speaker will be reciecing some bass....
    FYI - For me the "sweet spot" in the 600 series bookshelf range is the 602 S3 - which is a very capable speaker for stereo listenning even without a sub... Really worth a listen if you can come up with the extra $...
    Geoff
    • jrd
      • Dec 2003
      • 37
      I agree wholeheartedly with Geoff. I can't speak to the 600S3, but I started with 601S3. Had them probably 9 mos. to a year, then bought a pair of 602S3 and moved the 601s to the rear. All my other equipment stayed the same, so it was a fair comparison. The 602s retain the same nice tweeter, have even better mids because of the larger driver, and significantly more bass than the 601s due to the larger cabinet. I'm continually surprised how good the bass response is from a relatively small speaker.
      • biomed_eng_2000
        • 18
        Thanks guys for the input.
        I ended up getting the 601's. The dealer said that the 600 and 601 have near identical voicing but that the 601's have a slightly better dynamic range and slightly deeper bass because of the driver size difference.
        • BlazeMaster
          • 644
          very true....if money allows, get the 602s eventually and move the 601s in the rear. That's what I'm gonna do with my existing 601s. I kinda planned it this way becuz I got the LCR600 for center and I think the 602s blend with the LCR600 the best. Good luck..
          • benxx
            • 18
            How about DS602.5?
            I am considering DS 602.5 and DS603... IS LCR600 significantly better than LCR60?
            • Aussie Geoff
              • Oct 2003
              • 1914
              Benxx,
              According to B&W:
              For centre channel, the more compact LCR60 S3 can typically be used to partner the 600 Series bookshelf speakers or the DM602.5 S3 floorstander.
              The LCR600 S3, with its higher output and improved bass extension, partners either the DM603 S3 or DM604 S3 in larger home cinema installations.
              Bottom line - for the 603 S3 you really should have the LCR600 S3 - for the 602.5 it is more marginal - but...
              I have heard 3 LCR600 S3 as the front channels and they were superb!!!
              Geoff
              • benxx
                • 18
                Thanks Geoff,
                Is ASW600 good enough for the purpose or should I go with 650 or even think about 675? Still debating whether I should go with 602 as front and pay for a good pair of stand or go with 602.5 or 603 as front.
                • BlazeMaster
                  • 644
                  What's your room size? In my room I got the 601s as fronts and LCR600 as center. I don't have the surrounds yet. I'm quite satisfied right now without the sub, but that'll change when I move into a bigger place. Have you checked out other subs by different manufactures? I'm looking into the SVS and the HSUs, price wise, I believe they'll give you more bang for the buck. There's alot of good talks about them, give them a try.
                  • biomed_eng_2000
                    • 18
                    I'm using the 601s for the surround (four of them)...with three 602.5s for the L, C, and R located below a 106" front projection screen. Room is about 15' by 18'. Still waitng for FedEx to deliver the screen!!
                    • BlazeMaster
                      • 644
                      sounds like a nice setup biomed eng. Post a picture when you finish your setup, sure like to see it. I'm actually going to keep my 601s as the fronts and pick up a pair of 600s and DS6 for surrounds. Planning on a eventual upgrade to the 700 series, can't wait.
                      • dan87951
                        B&W DM600S3 vs LM1
                        by dan87951
                        Which speakers do you prefer for rear surround duty or even for a small bookshelf system in the home office (600S3 or LM1)? I had a pair of DM600S3's before and they sounded great for there size but the little LM1's remind me of a miniture 802 with the bubble tweeter on top, thought I might give them...
                        20 December 2005, 21:11 Tuesday
                      • allanpk
                        Rotel RA-01 X NAD C320BEE for B&W DM600S3
                        by allanpk
                        Hi people, I'd like to know the best integrate amplifier ($300~$400) for the DM600S3 bookshelfs!
                        I have two amplifiers in mind
                        Rotel RA-01
                        http://europe.rotel.com/products/specs/ra01.htm
                        NAD C320BEE
                        http://www.nadelectronics.com/hifi_amplif...
                        05 January 2006, 00:23 Thursday
                      • BWLover
                        RA-931 & B&W DM600S3 ???
                        by BWLover
                        Hello everyone. I am trying to help out a buddy of mine. He would like a budget stereo for his garage under $500. I have found the RA-931 for $200 and the DM600S3's for $300. Now with that being said. The Rotel integrated amp is a pretty old model and only has a spec output of 35WPC. Is this going to...
                        11 July 2009, 11:30 Saturday
                      • hiro
                        Rotel RSP-1066 Bass-management
                        by hiro
                        Hi everybody!
                        I'm new user ops: in this forum and congratulation for the quality posts! I'm also french and please do not take care of my poor english!
                        I've got one question :?: and one suggestion :idea: from a newbie! :roll:
                        The first one is for Andrew: is the new firmware v1.47...
                        30 November 2002, 04:38 Saturday
                      • george_k
                        SQ difference between digital and analog outputs
                        by george_k
                        I just purchased a squeezebox and was comparing the unit's DAC against the DAC inside my receiver (connected via digital coax).
                        At the same volume level I noticed that the mids and highs sound clear using the analog outputs but the bass is lacking. The digital output has slightly lesser...
                        03 December 2005, 23:18 Saturday
