Has anyone experienced this -- the wood veneer at the back of the curved cabinet, where the wood veneers join/meet up, starting to separate. In other words, a gap develops at the point where the veneer meets up. Can be seen as a straight line running from the top to the bottom of the cabinet back. Can of course be felt too when you run your fingers from side-to-side of the cabinet back.
If you have, appreciate if you could let me know what solution had been suggested to you to remedy this problem. Seems to me that patching up with wood putty is just a temporary cover up job only that may not last for very long. But what else can be done? Must the cabinet be replaced?
Thanks in advance.
Thanks in advance.
