Difference Between ASW CM and ASW 700?
  • Tweak
    I have been researching subs for a while now, and have narrowed my decision down to probably a B&W ASW CM or Velodyne SPL-1200. I want a tight, accurate sub, that doesn't take up a lot of space and compliments my current system in terms of apperance. These two choices fit the bill.
    But now I see the ASW 700 is the same price as the CM, with nearly identical specs. Does anyone know if there is a difference between the two in terms of performace or resale value? Or if I go with B&W just get the one that looks better. Have listened to the CM, and was wondering if it is worth my time auditioning the 700 or if I should skip it because it will be identical to the CM.
    Thanks!
  • junior77blue
    • 635
    I would think the 700 series would be a better value, newer, highre resale value. CM series I thought was being phased out. But, as with anything audition it before you buy.
    • asrovnal
      B&W ASW 700
      by asrovnal
      First post. Dose anyone have any comments on or experience with the ASW 700. Thanks
      06 August 2005, 20:03 Saturday
    • efarstad
      Appraisal/Resale value of Home Theaters
      by efarstad
      Hey gang...thought I'd share a tid bit since it's been thrown around so much. That is what does a theater room do for resale/pricing of a house. I just signed my refi paperwork yesterday (yes taking advantage of the great rates) and therefore had to have an appraisal done on our abode. Well it turns...
      10 June 2003, 12:50 Tuesday
    • perla4u
      Used Sub Woofer - ASW 800 or ASW 700?
      by perla4u
      Folks,
      I am in the market for a used Sub woofer and a quick look at audiogon, I found 2 Subs that are in my price range. A used ASW800 and an used ASW700 (actually 700 price is 150$ more than 800 in the listing). Any other better subs in B&W line? I do see ASW825 for sale but for...
      23 October 2009, 10:57 Friday
    • asrovnal
      ASW-700 Update
      by asrovnal
      Received the 700 on Friday the 12 of August. It sounds grate! Played U-571, several of LOTRs, and many other DVDs. On the music side my 703s seemed more open with the 700 and intergrated perfectly with it. A good buy and fit for my room. Now what - Rotel power?
      19 August 2005, 23:10 Friday
    • pramod
      Need advise in deciding on 700 series for HT setup.
      by pramod
      Greetings to all of you,
      Folks, I need some advise to help out my dear friend who is dependent on me to take a decision. we have a B&W sale with good discounts on 700 series. and the dealer is advising us to go for the following below (with our budget and can be stretched little...
      08 April 2009, 02:14 Wednesday
