I downloaded a handful of SPL apps only my iPhone 6 and iPad mini tonight, and after several tests while watching game of thrones with the devices @ 1m from the right main, I was getting 50db average and 60 peak. This seems incredibly low based on what I read others listen at, but any louder for me would be bordering on uncomfortable. Are my readings way out to lunch? The bottoms of the devices were pointed straight at the speaker. Thanks.
Average listening SPL
If you have an AVR that is designed to match (within an appropriate room size), reference level audio from a mastering soundstage for cinema, it should reach that point on the volume dial at 0dB. Depending on the AVR, the noise for setting levels generated for your audio setup should either read at 75dB (on a C-weighted SPL meter) or 85dB (can't remember offhand why some differ--I'm sure Google has the answer). If you have one where 75dB on your meter is the level of 0dB on your AVR display, and you tend to listen at -20dB on the volume dial, then your readings seem correct (though, IIRC, the readings are supposed to be done from the listening position, not from up close to the speaker--been a while since I've setup an AVR). I usually listen to movies at -20 (sometimes, for visceral impact with blockbuster movies--when the house is empty--I'll go to -10 to -15) below reference. For music (as CDs and other media are not calibrated to movie audio standards), I find a setting of -30 often sufficient (especially if it suffers from poor dynamic range at the mastering stage). Older, or recordings with wider dynamic range, often get bumped up as much as 10dB on the volume dial at home.
Clean, loud audio is nice but can be difficult to achieve (or tolerate in smaller rooms--my room is small).- Bottom
Many AVRs offer the option to view volume as an absolute value (like your display) or as a relative value (-dB) as I have mine set up to do. Should be an easy switch in your settings menu if you're curious.- Bottom
be wary of SPL apps for your phone.
many (if not most) are not accurate.
do not rely on one until you can compare its readings to a known source.
i have one of the old Radio Shack analog meters that apparently are no longer available, which i purchased many years ago for ~ $30.
this is an example of one similar to mine:
LINK
this link is not my meter nor do i have any association with the seller, just using it as an example
btw, if someone has or gets one to the Radio Shack units, its low-level accuracy is slightly flawed but can be corrected using the following correction factors:
10Hz +20.5
12.5Hz +16.5
16Hz +11.5
20Hz +7.5
25Hz +5
31.5Hz +3
40Hz +2.5
50Hz +1.5
63Hz +1.5
80Hz +1.5
100Hz +2Last edited by wkhanna; 12 July 2016, 12:18 Tuesday. Reason: clarify link is not mine or owned by someone i know- Bottom
Meters are great for balancing things out but, I wouldn't raise my listening level based on what a meter says. I would use it to lower my listening level though if by using it I discovered I was potentially damaging my ears. Occasionally it is probably ok to listen to a HT at public theater levels or music at close to concert levels but, it doesn't take much to do damage. I worked as a roadie way back when and I have decreased hearing acuity that may be due to those years. So, be careful.- Bottom
by JuzamShort version: Will the CM10s produce more volume running on the same equipment than 683s2s ?
Long version: I have a Rotel RB1582MKII poweramp and a Marantz KI-Pearl Lite I use as a preamp. The turntable (Audio Technica AT-LP5) is directly connected to the marantz's phono stage. The CD...-
Channel: Club B & W Speakers
by tmc1284I just purchased an LG 43UH6100 and also own a Sony XBR43X830C Smart TV. It seems that I am unable to control any of the display settings when using apps such as Amazon Video. I have the LG in my bedroom and want to lower the brightness and decrease the color temperature. However, for both the LG and...13 February 2017, 19:06 Monday -
by thylantyrWhat is the forum favorite tweeter {under $500 ea.} that
gives you amazing sound quality but also offers higher SPL
than what you might encounter from the average dome
tweeter? :lol:
The reason for asking is. The line arrays projects are
spreading in cyberspace...-
Channel: Mission Possible DIY
by gerardhnHi,
I have tryed many apps, many possible configuration to play over the ethernet input from CP 800.
I dont want to use PC/Jriver as configuration. I know it works.
The most obvious configuration is : DsAudio on NAS and use its app. It works but I dont like it: it disconnects,...-
Channel: Club Classé
by seattle_iceLatest Version 1.0.4.5 Posted 7:00 pm PST 10/7/09
Keep the feedback coming. I appreciate the effort from everyone who tries this. I plan on making it as full featured as I can.
IMPORTANT: Partially tested with Vista. Please let me know if you are running Vista or Win7 and...-
- Loading...
- No more items.
