Hum from inside CD player
  • madmac
    • Aug 2010
    • 3122
    Hi folks.....Not a big issue because the 'hum' does not come out of the speakers as sound but my Marantz CD-67SE has a very audible 'hum' to it when I'm near it changing CD's. Any idea why it's 'humming'??.
    Dan Madden :T
    Maybe it is a catchy tune.
    Do you recognize it? :W
    Seriously, is this something you just noticed?
    You sure it has not been making this sound all along?
    Maybe the transport/motor? Maybe the power supply?
    Hard to tell from here.
      Does it happen when there's a CD in it vs. no CD? If there is and it only happens when a CD is in it then it's the motor spinning the CD I would think. Other than that... the only other "motor" that would make a sound is for the tray opening and closing. Can't really think of anything else that would cause that.
      • Kevin P
        • 10812
        If it's a constant hum even when it isn't spinning a disc, it's probably the transformer in the power supply. This is common and doesn't indicate a problem with the unit, unless it's really loud.
        • madmac
          • Aug 2010
          • 3122
          I believe you are correct Kevin. It's most certainly the power supply/ transformer. It's happens all the time whether it's spinning a disc or not. Works great, no change in performance. The only thing I'm not sure about is whether it's always done this. This player is quite old (1998). :E
          Dan Madden :T
          • madmac
            • Aug 2010
            • 3122
            All my tunes are catchy so that's probably it!!
            Dan Madden :T
              Awww, you beat me to it! I was going to say, "maybe because it doesn't know the words?"
                • 27460
                Skynet is becoming self aware. The sound is a beacon sound to wake up all the other machines in the theater, soon wireless connection is established, and connections with other theaters worldwide will be established, as Skynet continues to spread the virus.
                Seriously, about all said here is about what there is to know.
                  Man that means that the RIAA is going to be suing Skynet because then all the CDPs will start sharing the music and the RIAA wants their cut! :P
                    madmac, I suspect that it's the Harakat Ul-Mujahideen (HUM), a Pakistan-based Islamic militant group with close ties to the Pakistani intelligence agency (the ISI), sending you a message. Just why they have chosen to contact you via your CD player is anyone's guess.
                    • madmac
                      • Aug 2010
                      • 3122
                      Ok now I'm paranoid!!. :E I've tossed the CD player out the window......that's that !! :T
                      Dan Madden :T
                        Well... I guess that's one way to deal with it!
                        Now, if the player starts talking to you, then we have a whole 'nuther problem.
                        hhhhhhhmmmmmmmmm....put on a pink tutu.....hhhhmmmmmmmmmm.........shave your head.... hhhhhhmmmmmmmmmm........move to Montana.....hhhhhmmmmmm......build a shrine to Ethel Merman....hmmmmmmmmm...
                          Ahhhhhhh.............Ethel Merman.............
                          :roflmao:
                          • pcernicky
                            CA-5300 AC hum
                            by pcernicky
                            I just received Ca-5300 and when connected either to ac directly or thru ac cleaner, once turned on i can hear with each click hum coming from the rear of the unit. I contacted the Classe support but they just recommended to send it for repair if the hum wont disappear.
                            07 April 2020, 13:56 Tuesday
                          • specialized
                            Denon 3808 and buzzz sound from inside?
                            by specialized
                            I have Denon 3808 and i noticed that there is some buzzing sound coming from inside.. It's not something loud, but when i put ear like 10 cm from the device i can hear that buzzing... Sound is only there when i turn on the receiver(green button) (there is no buzz sound in standby mode (red button))....
                            21 September 2008, 08:34 Sunday
                          • flyboylr45
                            Oh Oh. RSP 1068 hum...
                            by flyboylr45
                            My brand new Rsp 1068 started humming. I have had this processor for about 3 weeks. I moved a couple of things around, and found that you can only hear the hum when the component monitor output is connected. I think that the problem is that these wires run side by side to the tv power cable inside...
                            26 February 2007, 22:59 Monday
                          • benezrj
                            Slight Hum Since Adding the 5250
                            by benezrj
                            I just purchased a Parasound New Classic 5250 5-channel amplifier and am now using my 7-year old Sony ES30 receiver as a front end processor until I upgrade to a dedicated prepro.
                            I have a question or two about some faint hum I’m hearing when I get close to the speakers (when both the...
                            17 June 2006, 17:55 Saturday
                          • Al K
                            SOLUTION to my RB1080 hum!!!
                            by Al K
                            Thanks again to the club members that helped me determine the source of the hum through my speakers! ( As posted previously, hum appeared with the addition of a new RB1080 added to sysytem). The source in my case was the tv cable! I never mentioned how I permanently solved the problem!! So here is the...
                            28 February 2004, 09:03 Saturday
