AES/EBU digital connection?
  • kpodolski
    • 314
    Can I use a plain ol' XLR cable to connect the AES/EBU digital out on my CD/DVD player to the AES/EBU digital in on my pre-pro? Or should I spend the money for a specific AES/EBU digital XLR cable?
    thanks!
    The second place winner is the first place loser.
    An argument with reality is one you'll never win.
    If you are offended, you are complicit in the outrage.
    It's better to drive a slow car fast than a fast car slow.
    "Americans love a winner. Americans will not tolerate a loser." Gen. Patton
  • aarsoe
    • 795
    It will work but the cable discussion is a rathole. If you already have a cable then use it and see how it works...
      • 27460
      Actually, the impedance is different. There is specific cable made for AES/EBU. It is NOT 75 ohm.
      I happen to have a little of it on hand I "think". I'd have to put a locator on it. (scrounge)
      Let me know if your interested in one.
      I used to have it on site, but had such little call for it, it eventually fell out of vogue.
      I'll make you a decent deal on it, if you want one.
      CATCables.com
      Remember us? We make cables here guys and happen to own the place! LOL.
        • 16038
        Lex is on the money- AES/EBU characteristic impedance is 110 ohms. It's important because of the bandwidth requirements and need to use a source and terminating impedance that matches to avoid ringing and signal jitter.
        • kpodolski
          • 314
          Cool! Thanks for the info guys. Wasn't quite sure...
            • 27460
            You can be absolutely sure about Jon's response. :-)
            I have pm'd you back now, sorry for delay, asleep at the wheel and doing other customer business, quite a bit actually.
