Good Looking Wall Treatments
  • Chris~H
    Newbie looking to get his feet wet. DIY comparable to B&W 802 Diamonds
    by Chris~H
    HI all,
    A quick snippet about me. I've been out of the audio scene for the last ten years or so, baby, house, wife, etc... In the past I've ran a few different setups, some old Klipsch LaScalas, Infinity, and my last setup was an Outlaw Preamp, Parasound amp, with B&W 6xx series...
    28 December 2016, 22:41 Wednesday
  • Saurav
    Questions for ThomasW about your DIY room treatments
    by Saurav
    Hi Thomas,
    I think this is going to be my next project. I went through your page, and looked at all the pictures in the links. I think I should be able to build these without killing myself Questions:
    * In your room, do you have these spaced off the walls like some people...
    30 April 2005, 20:03 Saturday
  • CupCak3
    Fabrics for Room Treatments
    by CupCak3
    How important are the fabric properties for room treatments? The treatments I’ll be fabricating will be for first reflections and bass traps. After searching around for acoustically transparent fabrics, they seem to be very pricey and most of them are not wife approved (the ones which she does like...
    20 July 2009, 12:01 Monday
    Important note on taking the feet off Zcustom units
    Important enough issue here to make a dedicated post. Like most any rack-able component, if you rackmount a Zcustom unit, you'll need to take the feet off the underside of the case. If you do take the feet off, do not put the feet screws back in the unit.
    I just did this with a Zcd. ...
    25 June 2013, 23:24 Tuesday
  • PiDD
    Acoustic Treatments
    by PiDD
    Hey All,
    After a lot of reading and all of your help I am one step closer to finishing the room.
    I have put 3" treatments at the first reflection spots and 6" in the front corners. The new sound is great... the biggest change is controlled bass and tighter mids...
    20 March 2005, 19:46 Sunday
