How important are the fabric properties for room treatments? The treatments I’ll be fabricating will be for first reflections and bass traps. After searching around for acoustically transparent fabrics, they seem to be very pricey and most of them are not wife approved (the ones which she does like are really $$$).
After playing around with the bonded cotton I’ll be using in my panels, it does not seem to me that the fabric will make a huge difference (assuming the fabric is not backed and can be pretty easily blown through). I’d really like to be able to buy whatever I need from JoAnn Fabrics or similar…
Thoughts?
Thanks!
Thoughts?
Thanks!
