Hi Thomas,
I think this is going to be my next project. I went through your page, and looked at all the pictures in the links. I think I should be able to build these without killing myself Questions:
* In your room, do you have these spaced off the walls like some people seem to recommend, or are they mounted on the walls?
* I have dipoles in a small room. I'm thinking that my first priority should be to prevent the back wave from reflecting off the walls, followed by reducing standing waves for bass modes, and then get the first reflection points. Does that make sense, or is that backwards?
* Assuming I have that right, I would want to start with 2 panels per side, on the front and side wall, behind and to the sides of my speakers. Your speakers are huge, and you've made really tall panels. How much taller than the speakers do they need to be?
* For room modes and bass, is it effective to put these panels on room edges (wall-wall or wall-floor) and build triangular panels for the corners? Or will I need to build cylinders/quarter cylinders to have any effects on bass? Also, these panels will end up being 2"-3" thick, depending on the wood chosen. How effective will that be at taming a 35Hz room mode?
Saurav
Saurav
