Speaker Connection Problems
  • caned_monkey
    I am currently having a problem with the spring clip speaker terminals on the back of my amp. The clips on two of the terminals don’t seem to be gripping the wire properly and so the sound cuts out or goes quiet intermittently. It’s very annoying because I keep having to stick my arm round the back of the amp and jiggle the wires around until the sound comes back.
    I've tried holding the wires in place with tape and blu tack but that doesn’t seem to work and I’ve tried to wedge them in with a match but the hole isn’t big enough to fit it in.
    Anybody else had a similar problem? I’d be interested to hear any ideas of how I can get this fixed because like I said it’s damn annoying.
  • Kevin D
    • 4601
    I've had good luck stripping about 1.5" of wire and folding it in half. Once you insert it and have the spring clamp down, pull it back. This should flare out the wire making contact and keep it snug.
    Kevin D.
      • 4158
      If you're comfortable with soldering , you can just replace the spring clips with binding posts. You can get a nice upgrade for little money that way.
      • bowlman
        bi-wire help
        by bowlman
        I just purchased a parasound 2125 2 channel amp..What is the best way to bi-wire? This amp has speaker A and speaker B connections. Should I just use speaker A connections or hook the tweeters to A terminals and bass to B terminals? Or one speaker to A terminals and one speaker to B terminals?
        14 July 2006, 22:30 Friday
      • Kobus
        Incorrect Bi-wire: any damage
        by Kobus
        So today my installers came over to help with new tv setup etc.
        While here I asked them to assist me in swopping my speakers around.
        They ended up messing up the connections of my bi-wire setup at the one speaker end. They connected one wire (+-) to both positive terminals...
        27 July 2013, 11:16 Saturday
      • ht_addict
        BI-wire question
        by ht_addict
        I'm going to Bi-wire my new Paradigm Studio 40's and CC470v3 and was wondering should the runs of speaker wire be the same length for the front soundstage(FL: 1ft, FR:7ft, Center: 4ft from amp, so should I make all runs say 8ft). I know the runs should be the same length going from the amps +/- to both...
        22 September 2003, 12:34 Monday
      • nomad
        im back (cable help)
        by nomad
        For those of you who don't remember, and I'm sure there are plenty :W
        http://www.htguide.com/forum/showthr...ighlight=nomad
        I ended up with Rotel all around. I checked out all the suggestions at my local high end stereo shop. I was very happy with the performance/price...
        07 July 2004, 21:42 Wednesday
        Bi wire experiences
        by Briz vegas
        This is not so much a cable post as a hook up post, although I am sure the mods will make the call.
        I've run 804s for about 4 or 5 years now and probably will keep them for a while yet. A friend commented recently that I have the most tweaked system he has seen and it certainly is right...
        17 March 2012, 07:26 Saturday
