Where to find plate glass brackets.
  • Thirsty93
    • Jan 2009
    • 58
    I have a peerless av stand that has glass shelving and I want to make it stronger.The brackets that are on it are plastic,anyone know where I could get metal brackets for the glass?
    Your sound room is only limited by the amount of money in your pocket.
  • Thirsty93
    • Jan 2009
    • 58
    anyone?
      Thirsty, any well-stocked hardware store should have a selection of brackets for glass shelving. Barring that, one of the "big box" stores (Home Depot or Lowes) may have them depending on whether it's an "A" store or not. Then, try contacting a local glass company. If they don't have them they will probably have a source list.
      • Aussie Geoff
        Wall Brackets for 705s??
        by Aussie Geoff
        I am thinking of installing B&W 705s as my rear surounds. Does any one know of any wall brackets to suit - they don't seem to have obvious mounting holes and I don't want to have to drill into them
        Geoff
        13 November 2004, 09:32 Saturday
      • evilskillit
        DIY Plate Amp
        by evilskillit
        I have built a pair of subs to match my DIY bookshelf speakers, they're pretty basic and only need about 50 watts each max. I was thinking about getting on craigslist and buying the cheapest amp or receiver I could find just driving them with that and building a passive line level crossover. I found...
        21 February 2009, 21:36 Saturday
      • ht_addict
        Glass vs Plastic Optical cable. Any difference
        by ht_addict
        Just curious if there is any difference in performance when it comes to glass vs plastic for optical cables. I know of a website that has glass ones priced similar to plastic ones.
        ht_addict
        04 February 2004, 23:55 Wednesday
      • alpina
        what thickness glass should i use?
        by alpina
        hi all,
        rack design nearing completion.
        if using glass shelves, what thickness / type of glass do you guys recommend? heaviest individual item on a shelf will be 36kg
        thanks
        julie
        11 June 2006, 09:29 Sunday
      • 64NOMIS
        Customizing The Dayton Aluminum Binding Post Back Plate
        by 64NOMIS
        I have been customizing the Dayton binding post back plate from partsexpress.
        I needed a small rear plate with four holes for four connectors. The crossover is in the unit base and for no good reason I am running two ground lines up (well, I guess the cable is paired...). So I bought...
        13 May 2009, 14:59 Wednesday
