Switch to digital TV question
  • Pez
    • 472
    When TV goes to digital I get the fact that people who use an antenna as thier only source will be affected but what about these situations:
    1) You get your signal from the cable company but and its an older TV and DO NOT use a set top box, what happens then? What if you TV is a digital TV?
    2) Same as above but you do have a box?
    3) Same as 2 but you have digital cable?
    I guess what I am trying to figure out is who excatly needs to get the converter box that they are giving rebates for? And will you need this converter box in addition to the cable company's set top box?
    Twin Moderator Emeritus
    • 16706
    If you have an old analog TV with no built in digital tuner you WILL need a digital set top box of some sort. If you already have a STB/digital cable you should be fine. If you have a digital TV with built in digital tuner you'll be fine. (Though you may not be able to use all of the extra functions your cable provider has like VOD/PPV)
    • Kevin P
      • 10812
      1) depends on what the cable co. decides to do. TV going digital only affects OTA and the stations. The cable companies can still choose to carry analog signals over cable, though I expect most would switch entirely over to digital to free up bandwidth for more shopping channels.
      2/3) If you have a digital box, you will be all set. If you have an analog box, and the cable co. stops carrying analog signals, you'll have to replace it with a digital box.
      The rebates are for OTA converter boxes. So it's for those who use rabbit ears or roof antennas with analog TVs.
